Forums General Discussion Yacht Thruster
Viewing 28 reply threads
    • #221302
      calicojack
      Has anyone installed one of these external bow thrusters? I’d like to get rid of my brown bag with eye holes that I use when docking so no one recognizes me. I’d like to know how effective they are.
      Thanks / Jack on “MOJO” in Oriental, NC
      Calico Jack
    • #221308
      Jack
      I self installed a 24v 300S on our boat in 2013. The same forward battery is used to power the Windlass.
      I did all the install work except for a fiberglass pad that needed to be built on the hull where the unit lives.
      This unit works great when the wind is less than 15 knots. Above 15 knots I've sometimes wanted more ummph.
      I'm not sure one of their duplex units could be fitted on the 424 but it would be worth investigating. Also not sure if it would be cost effective. I'm not sure how much more $$ I would have put into a thruster to get the extra uumph I only rarely need.
      I (and the Admiral) will never go back to docking or maneuvering in tight marina quarters (fueling) without a thruster of some type.
      Eclipse #73
    • #221309
      calicojack
      Thanks Rick I really appreciate the info.
      Best Regards / Jack
      Calico Jack
    • #221312
      calicojack
      Hi Rick
      I think I’m going with the same installation. With the 24V system how do
      you handle charging the battery?
      Thanks/ Jack Coulter
      Calico Jack
    • #221313
      Jack
      I think you have the wrong member address.  I didn’t put in the bow thrusters.
    • #221314
      Everyone,
      When you send an email to the site/through the site, it sends an email to everyone who is subscribed to that forum – even though it looks like the email is addressed directly to you, it is not. For example:
      This email will show up to your address, but when you hit reply to, it will suddenly change to general@pearson424.org.
      So when you address an email to someone, it’s ok – don’t think you’re getting the wrong email. It’s your invitation to participate. And we need to capture these conversations for the community anyway!
      I hope this makes more sense!
      Pearson 424 Site Admin
      info@pearson424.org
    • #223019
      garmoa
      Thinking about installing an external bow thruster. Any additional update from anyone who has installed one? Thanks.
    • #223023
      I talked to a salesman at a boat show a few years back about the external units. They look to be of pretty good quality and I haven’t heard anything bad about them. Of course you can expect a reduction in sailing performance on the order of half a knot I am told, but I don’t think it should be that much based on what I saw. I believe the fellow told me that one had been installed on a 424 and the owner disagreed with the maker of the unit regarding it’s installation. Specifically the angle at which the unit was mounted. He reportedly felt a more ‘streamlined’ arrangement would work better and had an angled shim of some sort installed. The company disagreed but did it anyway. That’s all I know. Perhaps the individual who had this unit installed will read this and enlighten us further. I too am intrigued by the idea but that will have to wait, probably indefinitely.
      #189, Blue Moon
    • #223026
      Gary Moates
      Thanks, David. I just purchased one on Amazon at a good price. I’m wondering how the forward water tank might force me to mount it more aft than recommended.
      Gary
      #116
      JB Moates
      • #223027
        Gary…
        Not sure you saw my repost of what I sent last year to CalicoJack.
        Hopefully he will chime in as well.
        I installed mine immediately aft of the front water tank. Plenty of room there for the post and electrics… just not much room to work in..
        This unit works great when the wind is less than 15 knots. Above 15 knots I’ve sometimes wanted more ummph.
        I’m not sure one of their duplex units could be fitted on the 424 but it would be worth investigating. Also not sure if it would be cost effective. I’m not sure how much more $$ I would have put into a thruster to get the extra uumph I only rarely need.
    • #223028
      Gary Moates
      Hi, Rick. Yes, I saw your post and it was helpful. Just checking to see if there are any additional updates. Thanks.
      Gary
      #116
      JB Moates
    • #223029
      Gary Moates
      Rick, does your windlass use a 24v battery or did you use a voltage converter? Thanks.
      Gary
      #116
      JB Moates
    • #223030
      The windlass is a lewmar 24v model. The thruster folks recommended optima batteries charged via a sterling 12v to 24v charger that feeds off of the house bank when it is being charged. This has worked well so far.
      BTW.. Yacht thruster contends that this unit offers no more drag than the tunnel style thrusters.
      Happy to answer any install questions once you get going…
      Eclipse #73
    • #223032
      Does anyone have a sense of how much the unit affects sailing performance? I know that’s pretty subjective thing but I am interested in general impressions.
      #189 Blue Moon
    • #223033
      Yes agree, any response will be subjective. I don’t think I noticed any difference in sailing performance. It’s possible I’m not good enough of a sailor to detect any difference.
      Eclipse #73
    • #223035
      Thanks for the observation, Rick
    • #223183
      Thanks for the observation, Rick. Any others appreciated…
    • #223186
      calicojack
      I really don’t see any drop in my sailing/powering  performance. I
      don’t see the 1/2 knot drop, It’s got to be insignificant. The Thruster bullet
      shape vs a conventional 12” hole in your bow area
      convinced me to go this route. “Your mileage may vary”.
      Jack
      Calico Jack
    • #223189
      Ben Frothingham
      Papaya has a bow thruster but I don't have before and after experience. I'm guessing the 20 inch fixed prop is worse though.
      Good luck. Ben
    • #223195
      calicojack
      Rick – I also used the 12V to 24V converter. My boat is coming out of the
      water next week. I’ll try to get some photos posted. I’m anxious to see if it
      has any barnacle fouling since install in Dec.
      Jack
      Calico Jack
    • #223198
      calicojack
      Rick:
      I installed the same unit. Mine is a little aft of the water tank bulkhead.
      I had the yard do the actual install and glass work and I did all the electrical
      work. The battery is in the space between the water tank and the bulkhead. I
      have the parallel switch in the “V” seat slot. As you said I have had it act a
      little slow in high winds. I also would never go back to docking without a
      thruster.
      Jack
      Calico Jack
    • #223201
      Ben Frothingham
      Just FYI my thruster is aft of the forward water tank and seems to work just fine.
      Ben.
      Papaya No. 81
      Ben Frothingham
      Cell 508-742-7049
    • #223204
      calicojack
      Hi David:
      I can’t imagine a more streamlined design,especially vs the conventional
      standard of a 10” to 12” hole drilled through the bow of your boat. What is more
      streamlined than a bullet/ torpedo shape? I honestly have not experienced
      a noticeable 1/2  knot decrease in boat speed, under sail or power. Even if
      I did have a 1/2 knot speed loss the trade off for fantastic maneuverability
      would be more than worth it to me.
      Jack   on “MOJO”
      Calico Jack
    • #223207
      Sounds good.  Any updates very much appreciated.
    • #223216
      #189, Blue Moon
    • #223219
      I replied the following to a similar question. No change since then.
      Jack
      Eclipse #73
    • #223222
      calicojack
      I installed one last December, wish I had done it 10 yrs ago! It works
      great, I even got rid off my brown paper bag hat with eye holes. I used to put
      it on when I docked in a congested marina!
      Deaton Yacht Service in Oriental ,NC was the service yard I used for the
      installation. They are an authorized dealer and very familiar with the
      unit.
      Regards / Jack Coulter “MOJO”
      Calico Jack
    • #223225
      Janie Ashworth
      We had a company from Florida install ours.  They travel around and that is what they do.  It was a bit scary watching them use a huge hole saw on the boat, but it went like clockwork.  It has made a big difference in the way the boat handles!
      Janie Ashworth
      217-556-1551
    • #223572
      garmoa
      New external bow thruster on S/V JB Moates, 1980 Pearson 424 at Houston Yacht Club.
    • #223578
      The Admiral and I just got back from a 6 weeks cruise of the Chesapeake.
      We were anchored in Lloyds Creek off the Wye River for a couple of days while the weather was rainy. We anchored using 100 feet of chain and 50 feet of 5/8″ 8 plait rode. The wind shifted around several times and sometimes it blew pretty good and at other times there was no wind.
      When it came time to weigh anchor and leave, I discovered that the 8 plait rode had lodged itself between the aft part of the external thruster and the hull. I could not dislodge it from the deck of the boat… so I went swimming. It was easily dislodged from the water.
      I have added an item to my winter haul out list… fill that space so it won’t happen again….
      Eclipse #73
