Forums › General Discussion › Wet muffler
- This topic has 4 replies, 3 voices, and was last updated 10 years, 11 months ago by
sumocean.
April 5, 2014 at 1:11 am #68878
cstewart
ParticipantI have a busted/ rusted muffler that was spraying seawater in my bilge, like a heavy pee stream. I sanded it and cleaned it and then put on a patch of JD Weld putty, then wrapped that with a daisy chain of hose clamps that went around the 10 inch diameter muffler. I sailed and motored 75 miles today to get home and everything held together beautifully. But it is a patch. Here is my delimia.
I don’t have a clue of what I need for a new muffler. Where do I start. Do you just buy a new one at West or is it something special that has to match the engine. It is the original W-60 with a SS welded can muffler.
Thanks for any ideas.
Charlie.
Sv/ OneEighty, hull 54 -
April 5, 2014 at 6:00 am #80799
ParticipantIf you browse around the Vetus website (
http://www.vetus.com/exhaust-systems/waterlock-muffler.html) or catalog I
think you find the information you are looking for.Regards,
Charlie.
sight of the shore."
April 5, 2014 at 1:55 pm #80802
cstewart
ParticipantThanks, John.
I looked at Vetus and wondered if the different models were capacity sensitive. It appears that the different models only refers to hose sizes. Question: if the Vetus is plastic, what happens to it the first time it runs hot?
Has anyone replaced one of these and what did you use?
Charlie -
April 5, 2014 at 2:52 pm #80803
ParticipantCharlie,
I have a plastic Vetus muffler on my Yanmar (
http://www.svsarah.com/Sarah/Images/Cabin/20080214FrigCompressor.JPG). I
wouldn’t worry about the temperature and at least it will never corrode.
I suggest you give Vetus a call on your installation.Regards,
http://www.svsarah.comOn Sat, Apr 5, 2014 at 9:55 AM, cstewart wrote:
Thanks, John.
runs hot?
Charlie
April 5, 2014 at 10:31 pm #80805
ParticipantCharlie
I have the old one from my W60 at home I think. It is old but was fine when removed. I would be glad to send it to you if want to give it a try. I installed a Vetus with the new Cummins. I also added a gooseneck from Vetus in the lazerette.
Just let me know if you want it and where to send it.Linus
