I have some good friends who just bought a new used boat, not a 424, with a Westerbeke 63C engine that has issues. I know little about this engine but I promised to do a bit of research to try and help them out. I found little on the web but thought someone in our group might have some answers to help out. I found that the 63D is a marinized Mazda B2200 S2. The 63C appears to be the same engine but I can’t be sure. Does anyone know what the differences are between these versions of the 63?
Briefly, they have a problem with their injection pump. The thing blows blue smoke. It appears that the pump has been replaced during a recent rebuild but the replacement doesn’t appear to fit quite right. My suspicion is a timing issue with the injection pump. The pump appears to be rotated to the end of its adjustment. A new pump purchased from Westerbeke is unobtanium. If we can determine if the correct pump is installed, and if not what the right pump is, we might save some money.
Thanks in advance
