Forums General Discussion Westerbeke 58 flowcontroller problems
  • This topic is empty.
Viewing 1 reply thread
    • #226013
      My 424 is an ’81 but with an ’87 engine. I recently had a cracked exhaust elbow spewing soot into the boat. My mechanic replaced all 4 elbows with new gaskets, etc and removed the manifold tank and flowconqtroller for cleaning. There is no longer an exhaust leak but the end result is we can’t adequate coolant to go to the hot water tank – so no hot water. I followed up after the mechanic – replaced all the 7/8″ hoses and even flushed out the coolant coil inside the hot water tank as well as the reservoir tank and T fitting in the port cockpit locker. STILL no hot water!! Has anyone had this problem? Are there special tricks to make sure the system has no air bubbles. I’m certain the flowcontroller “spring” is in place. I’m convinced the reverse position of the engine with V drive and the longer hoses and bends contribute to the problem, no?? Any advice is greatly appreciated. My W58 runs great; I can’t justify an engine replacement just to get hot water…..Bob T.
    • #226053
      My hot water flowcontroller problem has been solved! It turns out the mechanic damaged the diverter spring when he took apart the manifold to replace exhaust elbows. I would caution everyone that if you remove the flowcontroller for any reason make sure the diverter spring is in good shape and positioned well. Before assembly be sure spring fully covers second pipe hole or antifreeze won’t flow into first pipe hole to domestic hot water tank!
      Bob T.
