Forums General Discussion Water Tanks
Viewing 20 reply threads
    • #68874
      Hello to all waiting for spring…
      I have aluminium water tanks! This year I can not get system to work – a
      lot of air in lines… I am guessing the original lines have failed – that
      is leaking. How do you get to the tank hook up points for the p and s
      tanks – bow can see it? I slide the extension boards out and found two
      inspection lids one at bow end for the filler line and over flow line. At
      stern of tank and inspection plate. Can not see the out flow hook up.
      Looking under deck has not proved helpful. .
      Questions:
      1. Anyone with same set up?
      2. If I fully remove the extension board can I remove the sheet of plywood
      covering tank?
      3. Do you think I will be able to spot water line hook up point? Prepared
      to cut opening to do work….
      Any other suggestions would be appreciated.
      Cada Grove
      Jubilee 424 No 100
    • #80782
      Cada,
      I didn’t know any 424’s had aluminum water tanks.
      Silverheels’ are integral fiberglass, so I can only
      speak for this setup. The discharge hoses for both
      tanks are at the aft lower inboard corners of the
      tanks. Those hoses run directly to the freshwater
      manifold beneath the galley sink (in my L-galley
      layout). My access to those fittings is, as you
      guessed, under the tanks’ screwed down plywood cover,
      which I cut early on so I could remove just the aft
      4-or-5″ to get into that narrow space between the tank
      and its aft bulkhead. To run new hoses, though, I had
      to stand with my feet in the deep bilge sump and wedge
      my upper body underneath the cabin sole to reach and
      lead the hoses. Good to get to know that under-sole
      area in any case, with its plumbing and wire runs.
      I believe some smarter 424 owners have cut access
      panels in each tank’s aft bulkhead to access those
      water tank hose barbs, and to open up that wasted space
      for storage. Not sure how that works on the port side
      in a U-galley layout.
      Have fun!
    • #80783
      Cada,
      I did as Tor indicated others have done and cut an access hole in the
      bulkhead aft of the water tank. Here is a link to what I had to do:
      http://www.svsarah.com/Sarah/ewWaterTankLeak.html
      I also have fiberglass tanks. Either a PO ground out the original tanks on
      your boat and replaced them with aluminum, or yours is a very late model
      and Pearson had switched the tank set up.
      On Fri, Apr 4, 2014 at 7:40 AM, Silverheels wrote:
      Cada,
      Have fun!
    • #80784
      Thanks for feed back. Already checked and the water line hook ups are not
      at the aft end. Jubilee was original built as a charter boat and has a
      very extensive holding tank set up and prevents me from getting into bilge.
      Looks like I will be cutting access holes – after I check every thing
      again. Think I may revetse flow and see if I have a blockage at he intake
      end.
      Appreciate any additional input.
      Pete liked your new set up…I may go that route as part of what I think is
      going to be a major project of up grading the water system.
      Cada Grove
      Jubilee haul No, 100
      Cada,
      Have fun!
    • #80786
      The fun never ends.
      My boat came with a sizeable stainless steel holding
      tank occupying the space aft of the main mast,
      stretching almost to the edge of the sump cliff.
      Happily, it is removable. I pulled it to rearrange its
      hose connection fittings, and kept it out for a while
      so I could run new water hoses, mast wiring, forward
      (windlass) battery cable, etc, etc. I can slide it out
      through the floorboard hatch (above the sump) by myself
      and manhandle it out of the boat, albeit awkwardly.
      Can’t imagine refitting a 424 without full bilge and
      under-sole access, at least for a while.
    • #80787
      Thanks foer info. My al. tanks are just sitting in the compartment formed
      by the berth. Think I may be into a full removal of them for
      inspection/repair..
      Cada
      end.
      is going to be a major project of up grading the water system.
      Cada Grove
      Cada,
      Have fun!
    • #80788
      Tor,
      thanks for infor. I hoping not to have to go that far! My holding tank is
      not SS and there is a lot of pluming for the two heads and two Y valves.
      Cada
      inspection/repair..
      Cada
      not at the aft end. Jubilee was original built as a charter boat and has a
      end.
      Cada Grove
      Cada,
      Have fun!
    • #80789
      It sounds like you’re having trouble priming your water pump. My 424 originally came with a self-priming diaphragm water pump, but it went up in smoke many years ago and has been replaced by a sureflow wabble-plate pump. If air gets in there, it can sometimes be hard to get the thing primed. I have best luck with a full tank.
      there’s a foot-pump in the galley that is currently not connected. I have plans to hook it up to the manifold valves under the sink but I need an additional valve to do it right. It might be of use in priming the electric pump if I hook it up to the pressure side of the pump with a shutoff valve. It’s on the list.
      The foot pump was originally connected to the water tanks with T-connectors such that all three tanks fed the foot pump with no valves. This allows water to drain from the windward tank to the leeward tank. That’s why it’s no longer connected. The three hoses now serve as tank drains for wither layup.
    • #80790
      My foot pump either takes fresh water from a collected feed or salt. The
      selector is behind the trash can holder on the wall beneath the sink. We
      wash dishes with salt.
    • #80791
      yek… I have separate foot pumps for salt and for tank water.
    • #80792
      How many gallons and how in the world do you remove it? I once had an 8
      gal holding tank there… not very useful. Instead I pulled up a large
      piece of the salon sole and glassed a fuel tank into the hull – about 90
      gallons. (BWS article on that on my webpage dublerfamily.com)
      On 4/4/2014 10:02 AM, Silverheels wrote:
      The fun never ends.
    • #80793
      I set mine up like Thatcher’s, with a simple redirect
      valve. I’ve only ever used it for seawater dishwashing,
      but can instantly switch it over to the freshwater
      system if the pressure water pump dies.
    • #80794
      Hey Pete,
      Silverheels’ ss holding tank is around 40 gallons, I
      believe. To remove it I disconnect the hoses in place,
      remove a retaining fiddle-block at the aft end, and
      manually slide the tank back until its aft end can be
      tilted up and through the floorboards hatch.
      Considering I have not used the holding tank in 5 years
      it would certainly be more functional as a spare diesel
      fuel tank, but I figured in the unlikely event I ever
      want to sail in US waters a holding tank would be
      required equipment. Anyway, the 110 gallons of diesel I
      carry has proven adequate for the Caribbean cruising
      that I’m doing.
    • #80795
      I sure like our composting toilet.
      On 4/4/2014 2:07 PM, Silverheels wrote:
      Hey Pete,
      that I’m doing.
    • #80798
      I have a holding tank in the same location, but in my case it is only a 6 gal tank. How big Is your tank, gal or dimensions. I need to up scale mine since a 6 gal fills up vey rapidly.
      Steve
      Sent from my iPad
      On Apr 4, 2014, at 9:23 AM, “Silverheels” wrote:
      The fun never ends.
    • #80800
      Steve,
      My tank measures 13″ x 13″ x 38″. This 6,422 cubic
      inches, I just discovered with an online conversion
      table, is a tad shy of 28 gallons, not the 40-gallons
      my spec sheet said. Live & learn.
    • #80801
      Pearson, on Jubilee, did a really nice job. All three tanks are feed to
      under the sink where they installed a very high quality bronze set of
      controls. One for each tank and one as a by pass to a whale foot/priming
      pump. What is happening is that I am getting a lot of air mixed in with
      the water so that I can got get a good prime for the pump. We had a very
      hard winter, did put in RV winterizer solution for water systems, so I
      either have a damaged line or some thing is blocking the intake at the tank
      and the pumps are pulling in air some place to prevent a good prime.
      I am first going to try to reverse the flow by connecting a water hose at
      the pump end and blowing it back towards the tank to see if I can clear the
      line. Maybe a new foot pump and start over with the rocess (foot pump is
      20 years old). If that does not work I will be forced to remove the board
      that slides out by removing the two pieces of wood used as a slide tracks,
      then remove plywood cover. Hope I can then see where the connection is and
      replace the line. At this time I can see no signs of leaking.
      I appreciate all the ideas and info… As my wife has been telling me this
      is a simple basic system – we just can not get to it! I wish some of the
      Peasrson designers were still around so I could ask them WHY!
      Cada Grove
      On Sat, Apr 5, 2014 at 7:45 AM, Silverheels wrote:
      Steve,
    • #80804
      If your blow-back idea doesn’t solve the problem, try
      tightening every hose clamp in the system with a
      ratchet wrench before you tear everything apart. I’ve
      remedied similar issues this way more than once, even
      when there was no evidence of water leaking.
    • #80808
      cbboat
      I had same symptoms you describe, lots of air mixed with water. Solution was to tighten hose claim I had forgotten to tighten. Maybe you have a crack in a line and it is sucking air.
    • #80809
      That is the plan.. I checked Sat. and there does not appear to be any leaks
      at the tanks. I also notice the galley pump was producing water on only
      downward pump – should also produce [um[ on up strole. Ordered a new
      galley pump!
      Gone away for a week – will let everyone know what happens when I return.
      I will definitely check every connection.
      Cada on Jubilee
    • #80849
      Final update on fresh water problem. It took awhile but I found a hair
      line crack in the plastic water filter/strainer. Just enough to break prim
      on both the foot pump and electric pressure pump. Replaced and now working
      I still want to locate the where the tank connections are on the port and
      starboard ones. they are aluminum and hook up is not at the ends -another
      smart move by the design team.
      Thanks for all the suggestion on my problem.
      Cada Grove Jubilee No. 100
      leaks at the tanks. I also notice the galley pump was producing water on
      only downward pump – should also produce [um[ on up strole. Ordered a new
      galley pump!
      Cada on Jubilee
