Forums › General Discussion › water tanks
- This topic has 3 replies, 4 voices, and was last updated 14 years, 11 months ago by
madsailor.
April 9, 2010 at 3:05 pm #67964
ParticipantHello All
I have just installed a port in the forward end of the water tanks. When I started cleaning I thought that there was just one baffle in the middle of the tank. After being able to reach in both ends I found there is a second baffle. This makes three separate sections in the tank one that I still can’t get to. The tanks were nasty. I was inspired by Pat’s picture that showed a white tank. I had no idea that the tanks were white on the inside till I saw that photo. Both ends are now spotless but the middle section is a little funky, much better than before but still funky. Has anyone installed a third port to access the middle section to clean?
Sumocean #34
April 9, 2010 at 5:58 pm #75133
SpectatorI had three access ports (plastic screw-ins) on my starboard tank which I
believe has a broken baffle probably from freezing. In my port tank we
installed two ports. I highly recommend these stainless ports over the
plastic Beckson screw-in ones. See the post:
http://deepplaya.com/post/Installing-Tank-Inspection-Ports.aspx-p
On Fri, Apr 9, 2010 at 8:05 AM, Linus Martinez wrote:
Hello All
installed a third port to access the middle section to clean?Linus
Sumocean #34
April 10, 2010 at 12:20 am #75137
Phil Fontaine
ParticipantThanks to the previous owner my tanks have three ports. I am able to sponge
all of the water and silt out in the fall and I can wipe down all surfaces
with bleach water at the beginning of each season. However, the ports are
plastic and some of them tend to leak when the tanks are overfilled (which
happens most of the time). You may want to consider metal ports if you add
more.
Phil Fontaine
Aurora
April 10, 2010 at 2:44 am #75138
ModeratorFor metal ports, here’s what I used and how I did it:
http://thesailinglife.blogspot.com/2009/08/finishing-projects-holding-tank.html
Plates from Seabuilt.
Also:
http://thesailinglife.blogspot.com/2007/08/beautiful-solution.html which
shows how you could construct your own (I did a 2.5″ one for the mizzen mast
to access the wire runs…).If you have any facility at all with metal, you can make your own from 1/8″
stainless and rubber gasket material. Save you a ton of money.Bob
On Fri, Apr 9, 2010 at 8:20 PM, Philippe Fontaine wrote:
Quote:Thanks to the previous owner my tanks have three ports. I am able to
sponge all of the water and silt out in the fall and I can wipe down all
surfaces with bleach water at the beginning of each season. However, the
ports are plastic and some of them tend to leak when the tanks are
overfilled (which happens most of the time). You may want to consider metal
ports if you add more.
Phil Fontaine
Aurora
