Howdy all;
Summer has hit all of a sudden here in NW Florida. Pretty warm…
I asked some months ago for any info on water deck fill screw caps, as mine are so sun damaged that I can barely get my fingertips under them to remove when they are unscrewed. The standard offerings through various suppliers did not work. Wrong diameter, wrong TPI. Or both. I found a Perko cap that does work however. It is Perko catalogue number 1270DPW99A. One of you recommended I try Perko, can’t remember who. In any case it works! Screws down a bit too far, as it’s height dimension is a bit different than original, but not too discernible. Talking less than an eighth or so. Anyway, this info may be helpful so am passing along. This was a special order through my friendly West Marine dealer.
