Forums General Discussion Waste tank: What fits?
Viewing 4 reply threads
    • #68452
      Looking to replace stinky black water bladder with slightly less stinky hdpe tank under cabin sole. Anyone know what stock size(s) fit through floor hatch? Prefer no cutting to cutting.[/code]
    • #77889
      skipmac
      If you can’t find a stock tank, Triple M Plastics in Maine will make a custom tank to any dimensions you like. Price pretty reasonable as well.
    • #77895
      Thank you for the recomendation; now if I can figure out whether a stock tank fits (I’ve made 3 3d templates from cardboard so far) I’ll know if I need to make the tank, and even better, what dimensions to make it. Darned geometry. It’s the fitting through multiple planes that confuses me.
    • #77898
      patn
      we replaced ours with a standard 30 gallon tank (might be 31) from
      http://www.kracor.com
      I would have to look up the actual dimensions.
      We did have cut the framing around the hole to get enough space to slide
      it in.
      http://picasaweb.google.com/dhjppn/HoldingTankPictures
      – pat
      SV Doris E
      Adam Silverstein wrote, On 10/17/11 7:22 PM:
    • #77899
      Same here, except from plastic-mart.com
      We did have cut the framing around the hole to get enough space to slide it
      in.
      http://picasaweb.google.com/**dhjppn/HoldingTankPictures
      – pat
      SV Doris E
      maillist@server12.**websitehostserver.net
      http://server12.**websitehostserver.net/mailman/**
      listinfo/maillist_pearson424.**org
