- This topic has 9 replies, 5 voices, and was last updated 4 years, 2 months ago by
Rock Richardson.
November 25, 2020 at 1:13 pm #225818
Rock Richardson
ParticipantI re-powered with a beta max 50 have a standard shaft. would the 20 inch prop still apply. what pitch would i go with
what problems would i encounter
November 25, 2020 at 1:36 pm #225819
ParticipantWill you be reusing your transmission or getting a new transmission with your new engine? You need to figure out the rotation speed of your new arrangement. The betamax runs at 2800 RPM. Assuming no change in gearing, is this shaft speed close to what you already have? A good 3-blade folding prop will provide efficiency in forward similar to a fixed-blade prop. If the gear reduction is the same, a prop with the same pitch should provide about the same performance.
I assume you read my notes. http://www.richardcarter.net/repower/Propeller.html
Rich -
November 26, 2020 at 2:24 pm #225821
cstewart
ParticipantI would say a 20” is the right size for your configuration. I have a 21” and it is a bit oversized for my 55hp W60. I’m at cruising speed at 1500 RPM, and that’s not a diesel’s sweet spot. I definitely recommend the feathering prop and although there are several quality brands, I can only speak to the MaxProp which has served me well for 15 years. There are of course good and bad points of a feathering prop. When they are good, they are very very good. When they are bad, they are very bad. To the good, they do assist sailing speed and reduce drag. I’ve got a couple of first in class in races to attest. They power very well in forward and exceptional in reverse. It also seems to reduce the Starboard crawl in reverse. That may be attributed to its quick reverse stern-way which gives it more responsive rudder steerage. The MaxProp is dependable and durable. I’ve wrapped my share of crab pots and have twice had major jib-sheet fouls, (stupid captain error) one so severe that it bent the shaft and strut, but no damage to the prop. The bad side is that they do not perform well at all when they are fouled with barnacles or anything else. In that respect they react worse than a fixed prop. The other perhaps negative is that they are expensive. Maintenance includes not only keeping it clean, but a simple re-greasing on haul outs.
As for your pitch recommendation, I can’t give you that but the MaxProp is Configurable and can be tweaked (changed) on haulouts. -
November 27, 2020 at 10:52 am #225822
Bryan Bywalec
KeymasterI got a three blade flex-0-fold. After much back and forth with the vendor we settled on a 18×12-3 L bladeset, there is some discussion in the forums about this as well:
Response #1:
“I have a Wester 58; and replaced the original 3 bladed prop with a flexofold; and, am satisfied with the flexofold prop. Jack, the US contact for flexofold recommended an 18 X 12 – 3LH; and this was too much prop (eng would not reach 3003 rpm, smoked excessively at wot). I downsized; cant find the paperwork, but I believe to a 17 X 11; and, for my boat it is the correct size.Response #2:
“Our original was 20X13, same as listed in the 424 sales brochure. I always had the impression we were somewhat over-propped. WOT gave us somewhat less than the spec 3000 RPM, and a lot of black smoke. We changed to a 18X11 flex o fold, and it seems to be about right. Certainly not too weak. However, I was cautioned by flex o fold to not compare their prop to other props vis a vis the diameter and pitch. No usable correlation.”
Note that you can try the flex-o-fold for one week and then return it. Obviously not the easiest thing to take off in the water but you might even just be able to return the blades. I worked with Csilla B. Rasmussen, cbr@flexofold.com. The exact engine specifications and transmission ratio are very important.
So far I’ve been very happy with the prop.
Bryan Bywalec
S/V Pelican, Hull 209
Siren Engineering, LLC -
November 28, 2020 at 1:31 pm #225823
Participant18×12-3 sounds right to me. I have an 18.5×12-3 and it works well on my boat. I have a 75hp engine though. If I had to get a replacement, I’d go for a 13 pitch.
November 29, 2020 at 12:42 pm #225825
ParticipantMine is a flex-o-fold, 18X11. Compares very favorably with the original prop’s performance. I cruise between 1900 and 2300 RPM typically, but can hit 3000 RPM or so under WOT. Smoking of course, with the exhaust well under water and making eight or more knots at that point. I’ve cruised all through the Gulf, up the East Coast to Rhode Island and out to the Bahamas with this prop and am pleased with it. Took a bit to get used to having to hit it hard in reverse to stop the boat, but it does stop pretty quickly when I roll the throttle up. Gotta’ be careful when positioning straps when hauling the boat though. The blades tend to be folded while at rest and you certainly don’t want to lift the boat by the prop blades. I ask the crew to lift very slightly while I go below and attempt to turn the prop shaft by hand, If I can’t move it, we reposition the strap by coming in from the stern a bit.
#189, Blue Moon -
November 29, 2020 at 6:17 pm #225839
ParticipantWell I forgot to mention one of the most important parts in my previous post (see above)…
My engine is a W58, 58 horsepower.David
December 10, 2020 at 9:51 am #225858
Rock Richardson
Participantim not at my boat but i know the transmission doesn’t have the metal plate anymore. i need to know the gear ratio in order to get the right prop or so they say. its a 1981 pearson 424 had a westerbeke and a velvet drive trans. looking for the gear ratio, any one have any ideas ?
December 12, 2020 at 5:16 pm #225862
Bryan Bywalec
KeymasterMy W58 has a Velvet Drive as that is 1:1. The gearing happens in the V-drive. The original Walter RV-20 is listed as a 2:1 gear ratio.
Bryan Bywalec
December 15, 2020 at 8:32 pm #225864
Rock Richardson
Participantthanks to all
