Forums General Discussion Spinaker pole/Whisker Pole Track Storage
Viewing 11 reply threads
    • #66902
      While my mast is down, I was thinking about putting a
      track on the mast so when I do get some kind of a
      pole, I’ll be ready for it.
      Now the question is, so I can figure where to start
      and end the 18 feet of track, is about where the clew
      height is to deck level.
      I’d like to use this for both my headsail or asym
      spinnaker.
      Anyone out there have a track already mounted and
      where is it positioned?
      thanks
      You rock. That’s why Blockbuster’s offering you one month of Blockbuster Total Access, No Cost.
      http://tc.deals.yahoo.com/tc/blockbuster/text5.com
    • #69391
      Alan:
      The track on my mast for the whisker pole is only 2 ft long and it starts 2″
      below the mainsail track.
      Since I haven’t sailed the boat yet, I can’t give any input if this is the
      right position or not.
    • #69392
      Thanks Paul, I am assuming that the pole is then
      stored on deck.
      — Paul Lefebvre <> wrote:
      Alan:
    • #69399
      Alan,
      Are you planning to get a fixed pole around 18′ long, or a telescoping pole?
    • #69393
      “I am assuming that the pole is then
      stored on deck.”
      Yes, since it is a collapsing pole, it is stored on the stanchions. I assume
      you are going to store the outboard end on the deck and the inboard at the
      top of the track?? You may also want to add for offshore in a blow, deck
      storage as well.
    • #69394
      That was my thought. Maybe not 18’…. haven’t decided
      on the length yet. I just thought since my mast was
      down, it would be easier to put in the 100 or so
      screws on the ground rather than from a bosuns chair.
      — Silver Heels <> wrote:
      Alan,
    • #69395
      I’ve heard of that, but I am thinking it would be
      firmly attached to the mast, why would high winds
      change that… not like it’s going to come off. I
      could not imagine taking that 18′ length of pipe off
      the mast while the deck is a heaving and a pitchen
      I could be wrong though
      stored on deck.”
      storage as well.
    • #69396
      Apparently the reasons are to reduce windage and get weight down in a real
      blow. Also, if you get dismasted, you will still have your spin pole to jury
      rig something with.
      I assume you would be bringing it down to the deck level about the same time
      you are hanking on your storm jib to the inner stay 🙂 – hopefully before
      it gets to wild up there.
    • #69397
      Alan,
      I’m about to post a really beefy (3.5″ dia.), 16′ Forespar pole for sale on eBay. E-me at if you
      think its something you could use.
    • #69400
      Alan I dont have track mounted yet but it is alot easier drilling and tapping with the mast down. Also start at either one end and work to the other end, do not start at either end and work toward the middle. David
    • #69401
      Three drills: #1 for the hole, #2 for the tap, and #3 for the screw
      driver.
      Use a bit of tap-magic on the tap and you will have a much more
      delightful time at it.
      Also, use Tuf-Gel in every hole.
      http://www.sailorssolutions.com/index.asp?page=ProductDetails&Item=TG01
      wrote:
    • #69402
      I usually use a 5/16 transfer punch to make sure I hit
      the center of the hole.
      Ever hear of power tapping?
      Do you think Tuf-Gel is better than Lanacote. I have
      both?
      Thanks for the suggestions.
      #3 for the screw
      driver.
      a much more
      middle. David
