Forums General Discussion Rudder "bearing" -plastic
Viewing 10 reply threads
    • #93689
      While getting ready to repack the rudder packing, I noticed that the plastic “bearing” on the rudder shaft that surrounds the shaft and drops in place between the shaft and a strong wooden cross member has popped out of its intended location. Has anyone replaced this cheap plastic “bearing”? with what? and how?
      Thanks.
      Rodd
      Windseeker, #214
    • #93690
      Rod,This was brought to my attention several years ago by Jack Tyler.  He was looking for the source of some vibration while sailing across the Pacific.  He just pushed it back in place and put a hose clam around the rudder shaft to hold it in place.  That made me check my rudder post and sure enough mine was above the cross beam (pic attached).  Seems to be a common issue, if not a major problem.  I just pushed the bushing back in place.  I'm sure it is back up now.  I think I'll use the hose clamp solution if I don't hear of a better solution (not requiring dropping the rudder) on this thread.Regards,John Stevensonwww.svsarah.comSarah's Blog
    • #93691
      Rodd
      I’ve never had an issue with the rudder packing or post. One of these days I expect to be in there replacing the packing. I’ll be watching the thread.
      Hope all is well with you.
      —– Original Message —–
    • #93694
      Thanks John-
      Rich- I had a leak from the rudder packing (at least I hope it was from the packing and not from the strut thru-bolts). So I am going to repack this year. As for the “bearing”, I’ll probably just go with John’s suggestion of a hose clamp to keep it in place-
      Rodd
    • #93695
      Miss Kathleen
      I had the same problem. There was a hose clamp which caused some rust that eventually seized the plastic bearing to the shaft and wore away the wood base. Solved the problem by mounting a plastic 1 inch plastic plate over the existing bearing and which also served as a bearing. Works well.
      Cheers
      Dennis
    • #93696
      svtopaz
      Rodd or anyone else…. did you get any pictures?
      B
      • #94196
        Miss Kathleen
        Found some pics of the shaft – before and after. In the “before” pic you can see the rust from the clamp.
        The new base has a recess that allows the “old” bearing to remain in place, and also holds it down
        Hope the pics upload.
        Dennis
    • #93699
      I received it in a echo of my email from general@pearson424.org.  I received a second echo afterward without the attachment.  Never got echoes of my email before.Regards,John Stevensonwww.svsarah.comSarah's Blog
    • #93700
      Here's a link to the pic on my website: http://www.svsarah.com/Sarah/Images/Rigging/Rudder%20Bushing.jpgRegards,John Stevensonwww.svsarah.comSarah's Blog
    • #93701
      Let's try this again.  The server seems to strip a lot formatting off our emails.http://www.svsarah.com/Sarah/Images/Rigging/Rudder%20Bushing.jpgRegards,John Stevensonwww.svsarah.comSarah's Blog
    • #93702
      Easiest way is to post images directly on the site. We’re trying to address this and the formatting challenges soon.Sent from Outlook Mobile
      info@pearson424.org
    • #93703
      one more time: http://www.svsarah.com/Sarah/Images/Rigging/Rudder%20Bushing.jpg     The server strips carriage returns and line feeds.  I put a few spaces after the link, maybe it will work this time.  Regards,John Stevensonwww.svsarah.comSarah's Blog
