Forums › General Discussion › Re: Man that prop pushes (and walks) hard to starboard
- This topic has 2 replies, 2 voices, and was last updated 16 years, 10 months ago by
unabated.
May 8, 2008 at 11:49 am #66986
ParticipantExactly right – at 80% – 2700 I SHOULD be able to run
the engine without it being overloaded (the black
smoke). Not that I WANT to but I should be able to do
it. Now that I have the pitch at 12 inches I feel
better.
alan— Robert Fine <> wrote:
Hi Adam,
That seems right. I’m wondering why you’d want to
run the engine above
about 2 grand? Sure, the red line is like 3400 rpm,
at least for the W58,
and it has been said that diesels ‘like’ to run at
80% of their max speed
(or 2720 for the W58) (which I think is bullcrap,
mostly because just
because you can do a thing doesn’t mean you should
do that thing), but with
any machinery, running slower is probably running
better.Not only that, but it’s so noisy at higher speeds…
On Thu, May 8, 2008 at 4:30 AM, adam silverstein
<> wrote:Excellent survey question. Cruise 1800-2000, fuel
burn 3/4 to 1 1/4 gph.
Speed 6-6 3/4 kn
-Adam Silverstein(via iPhone)
On May 8, 2008, at 7:05 AM, “Robert Fine”
<> wrote:
Really? I cruise at 1900-2000 rpm at 6 to 6.5
knots. I can get the
engine up to 2400 rpm, but by that point it’s
trying to climb out of the
water. At 1900 rpm it’s burning about 3/4 gallon
per hour. At 2200, it’s
burning nearly 2 gal/hr. Since the gain in speed
of at most a knot isn’t
worth it, I just cruise right along.
What are your experiences with speed/rpm/fuel
consumption?
On Thu, May 8, 2008 at 3:17 AM, alan P <
> wrote:
I repitched mine from a 13 to a 12. Mainly
because I
thought I should have more engine RPM’s before
the
engine started to bellow black smoke. I have a
W58 and
now can get it past 2800 rpms. Not that I ever
run it
that high, mostly cruise at 22 to 2400.
— Syringa <<>> wrote:
Patrick
Hope you had a good trip back from Bellingham!
I
have been looking into the prop pull on
Syringa as
you know. (This is when the vessel is under
steady
steaming in forward at 1800 rpm or above)
(not
backing or docking) I don’t believe the shaft
is
off set (if it is it’s not much) and should
not
account for that much pull. The prop may be
over
pitched. I will let you know if or when I
come up
with the answer.
I would like to hear from anyone who has
changed
propellers or reduced the pitch.
Don
Syringa____________________________________________________________________________________
know-it-all with Yahoo! Mobile. Try it now.<http://mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ>
Your data on the web your way. No kidding____________________________________________________________________________________
May 8, 2008 at 11:52 am #69805
ModeratorHmm, I'll try that on my first outing. I think I can, I think I can, I think I can get to 2700….
better.
alan— Robert Fine < ([email][/email])> wrote:
Hi Adam,
That seems right. I'm wondering why you'd want to
and it has been said that diesels 'like' to run at
mostly because just
because you can do a thing doesn't mean you should
better.Not only that, but it's so noisy at higher speeds…
< ([email][/email])> wrote:Excellent survey question. Cruise 1800-2000, fuel
Speed 6-6 3/4 kn
engine up to 2400 rpm, but by that point it's
water. At 1900 rpm it's burning about 3/4 gallon
per hour. At 2200, it's
of at most a knot isn't
consumption?
because I
thought I should have more engine RPM's before
the
W58 and
run it
— Syringa << ([email][/email])> ()> wrote:
Patrick
I
Syringa as
steady
(not
backing or docking) I don't believe the shaft
is
off set (if it is it's not much) and should
not
over
come up
with the answer.
changed
Don
May 8, 2008 at 11:54 am #69807
ParticipantIt’s little unnerving at first…..
Hmm, I’ll try that on my first outing. I think I
think I can get to 2700….On Thu, May 8, 2008 at 4:49 AM, alan P
<> wrote:Exactly right – at 80% – 2700 I SHOULD be able to
run
smoke). Not that I WANT to but I should be able todo
better.
Hi Adam,
to
about 2 grand? Sure, the red line is like 3400rpm,
and it has been said that diesels ‘like’ to runat
(or 2720 for the W58) (which I think isbullcrap,
mostly because just
because you can do a thing doesn’t mean youshould
any machinery, running slower is probablyrunning
better.
speeds…
fuel
Speed 6-6 3/4 kn
gallon
speed
consumption?
because I
before
the
a
W58 and
ever
run it
— Syringa <<>>
wrote:
Patrick
Bellingham!
I
Syringa as
under
steady
(not
shaft
is
should
not
be
over
come up
with the answer.
changed
Don
Syringa
m2f
Read this topic online here:
<https://www.pearson424.org/bb2forum/viewtopic.php?p=831#831>
m2f
Your data on the web your way. No kidding=== message truncated ===
