Forums › General Discussion › re companionway hatch leak fix
- This topic has 6 replies, 4 voices, and was last updated 14 years, 2 months ago by
RichCarter.
December 14, 2010 at 3:24 pm #68200
ParticipantThere is a good write-up by Hal Sutphen on how to fix the companionway
hatch leak on pages 32-34 of this summary of the first year of best
Pearson 424 projects:
http://www.dublerfamily.com/Regina_oceani/Manuals/Pearson%20424/Ten%20year%20best%20projects%20summary.PDFOne of the things I scanned that will soon be available on the Pearson
424 owners’ website.Pete
On 12/13/2010 7:58 PM, Dawn Rodney wrote:
Quote:Hi everyone,
Patrick and I were out this weekend…yes we left the dock finally for a
nice weekend sail to Blake Island where we met 30 knot gusts and 3 inches of
downpouring rain over night. While we were tied to the dock in Blake, Deep
Playa sprung massive leaks (all above the water line) and now we have a
substantial leak in the starboard companionway that wasn’t there before. I
know that others have rebedded and properly sealed theirs previously. Did
anyone also try to seal up the gaps that are left even while the
companionway is closed? And if so, what did you use?
PS: we had an awesome down wind sail home and were cruising at 6.5 kts
flying just the jib. 🙂
Dawn
s/v Deep PlayaOn Sat, Dec 11, 2010 at 10:00 AM,<> wrote:
Quote:Send maillist mailing list submissions toTo subscribe or unsubscribe via the World Wide Web, visit
or, via email, send a message with subject or body ‘help’ toYou can reach the person managing the list at
When replying, please edit your Subject line so it is more specific
than “Re: Contents of maillist digest…”Today’s Topics:
1. Re: 424 For Sale in Australia (Patrick “Peaboy” Walters)
2. Larger portlights- [4]- SS- what size and what brands are
suggested? (joe shimkonis)
3. Re: Larger portlights- [4]- SS- what size and what brands are
su (Chuck Ruble)
4. scans of earlier newsletters (Pete Dubler)
5. Re: scans of earlier newsletters (Patrick “Peaboy” Walters)
6. Re: Larger portlights- [4]- SS- what size and what brands are
su (Joe Shimkonis)
7. Re: Larger portlights- [4]- SS- what size and what brands are
su (Patrick “Peaboy” Walters)
8. Re: Larger portlights- [4]- SS- what size and what brands are
su (joe shimkonis)
9. Re: scans of earlier newsletters (Pete Dubler)
Message: 1
Date: Fri, 10 Dec 2010 10:03:10 -0800
December 14, 2010 at 6:31 pm #76398
ParticipantPete
Will you give me your email I have something that should not be on the list.
December 14, 2010 at 8:48 pm #76402
ParticipantThanks.
On 12/14/2010 11:30 AM, Linus Martinez wrote:
Quote:PeteWill you give me your email I have something that should not be on the
list.Linus
December 14, 2010 at 9:36 pm #76403
Pete,
I tried the link:
http://www.dublerfamily.com/Regina_oceani/Manuals/Pearson%20424/Ten%20year%20best%20projects%20summary.PDFand it didn’t work for me. I am trying to fix a leaky hatch as well and can use
all of the help I can get.Lee
Quote:There is a good write-up by Hal Sutphen on how to fix the companionway
Dawn
su (Chuck Ruble)
su (Joe Shimkonis)
su (joe shimkonis)
Message: 1
December 14, 2010 at 11:52 pm #76410
ParticipantLee
Sometimes these long links are hard to use. Make sure the entire link is on a single line in your browser address bar. Alternately just type in the link through the word “manuals” and then click your way down the directory tree
Happy holidays
Dawn
su (Chuck Ruble)
su (Joe Shimkonis)
su (joe shimkonis)
Message: 1
December 15, 2010 at 1:37 am #76411
Thanks Rich for the details. What was that gasket material you used around
the hatch to seal any water from coming in through the water gaps? Is it a
foam that is encased in plastic?
1. Re: maillist Digest, Vol 13, Issue 16 (Robert Fine)
2. Re: re companionway hatch leak fix (Linus Martinez)
Message: 1
Date: Tue, 14 Dec 2010 13:14:43 -0500
December 15, 2010 at 2:53 pm #76419
ParticipantThe gasket material is what’s used for door weather-stripping. Its sold in any hardware store. It comes attached to three pieces of wood that are typically attached to the door frame. I removed the gasket and cut pieces of teak in a similar dimension to hold the gasket in place. The teak trim is attached to the outside edge of the hatch frame.
http://www.richardcarter.net/boat/pix/deckRepair/deckGasket1.JPG
Its not perfect but its easy to install and seems to work for me. Its also easy to replace. The only issue I have is that the hatch has play in it and tends to favor the downhill side of the track. This sometimes allows the gasket to pop-out on that side and I have to open and close the hatch to make it seal properly. I’m planning to put some kind if runner on the inside of the hatch lip so that it doesn’t do this. Its on the list of “things that aren’t broken but could be better”. Its been on that list for years now. At least the hatch doesn’t leak. Even if it were to start leaking again, the deck core is now sealed with epoxy so water won’t get into the deck core.
It is possible for aft edge of the hatch to leak in a heavy rain since there is no gasket there. I don’t find an occasional tiny drip there to be a problem. I sit on a mooring or anchor, leaving the boat to point into the wind. If I were tied to a dock I might find this to be an issue. With the lock hasp hole in the trim, it would be difficult to seal that end of the hatch.
