Forums General Discussion PSS shaft seal
Viewing 16 reply threads
    • #68747
      It is time to do something to the stuffing box. The yard suggested that I replace with a dripless shaft seal. No more worry about the age of the shaft log and no water in the bilge. Has anyone had any experience with these. I feel like in an old post someone said they had one installed.
      Sumocean
    • #79789
      Have had one for 9 years. Life is good.
      Sumocean
    • #79790
      I have had one in Whiffler for 10+ years without issue. A colleague of mine put one on a Pearson 53 and had to replace it with a std shaft seal while at anchor in Mexico after 3 weeks (obviously put in incorrectly or a defective part).
      Steve
    • #79791
      I am of the very humble opinion that old school is the best school. I’ve
      seen dripless packing fail and fail spectacularly. What’s more, when they
      do you have to remove the shaft to fix them. If your packing goes in an
      old school box, you just replace the cheap packing. In an emergency you
      can stuff shredded t-shirt in there to minimize water intake.
      Simple is better. If you remove your shaft to replace the hose, purchase
      one of the silicone rubber hoses available for certain at Sailorman in Ft.
      Lauderdale.
      defective part).
      Steve
    • #79793
      Indulgence
      I also have one…works but so did the old system. My thoughts were of having a dry, dusty bilge….but that didn’t happen ( water always find a way in)
      Not worth the money.
      Lauderdale.
      defective part).
      Steve
    • #79794
      Another vote for the PSS. Had one on my last boat – 30k n miles without a
      hitch – and now on Silverheels these past 6 years with no problems. Nice
      when something just works.
    • #79792
      We have had a Lasdrop shaft seal for about a decade with good service. A couple things to consider.
      The seal depends on a carbon ring on the corrugated hose pressing on a stainless ring on the shaft. It will leak a little, necessary to cool and lubricate the seal. When launching, it is necessary to burp any air trapped in the hose to wet the seal and prevent overheating.
      The stainless ring seals to the shaft with O-rings. If the shaft is worn or scored where the O-rings seat, you might need a new shaft.
      Said ring is held in place with setscrews. It’s best to back this up with a hose clamp or a shaft zinc.
      If it was a do over, I might go with a traditional stuffing box and more high tech stuffing, at least Teflon stuff.
    • #79795
      I used to use the graphite impregnated packing – it ran cool, dry and
      forever. Well, years anyway. Then big news! Graphite promotes galvanic
      corrosion! Don’t use it! You’ll die! The world will end! You will get
      various diseases! You must use the teflon impregnated packing.
      Long and short of it: Graphite is still good. Runs cool. Doesn’t creep
      like teflon. And apparently the whole galvanic corrosion thing is a
      non-issue.
    • #79796
      I installed a Tides Marine Sure Seal in Eclipse 3 years ago. No problems so
      far.
      https://www.tidesmarine.com/
      Evan Starzinger has it on his list of top equipment on the boat…
      http://www.bethandevans.com/equipment.htm
      Had a PSS on a previous boat… no problem with that either.
      Eclipse
      Sumocean
    • #79797
      New generation of Lasdrop does not depend on the corrugated hose but
      instead on a spring loaded assembly. I added one of these new ones
      during our refit. Earlier generation of this with corrugated hose on
      our boat worked very well.
    • #79798
      At present I don’t know anything about these drip less shaft seals (with springs too?) but I do know without a doubt that as Bob and Indulgence hint at, that the old stuffing boxes have been working OK for a long. long time. Simple machined bronze to bronze, unbreakable really, with an inexpensive, easily replaced waxy stuffing that if you actually do regular maintenance tightening will keep your bilge dry. Guess I’ll have to study the advantages or not of the PYI drip-less shaft seal that’s installed on my soon to be floating home.
    • #79799
      Pete,
      I installed a PSS shaft seal on Sarah in 2001. No problems in the last 12
      years. I replaced the standard stuffing box because I had a constant leak
      of water into the bilge. It looked like it was coming from the stuffing
      box. Turns out the leak was from the stuffing box on the rudder post.
      I’m satisfied with the PSS seal, but probably would be just as satisfied
      with the stuffing box.
      Writing a New Chapter Page by Page in an Old Book.
    • #79800
      No disagreements. Restuffing the rudder gland was on my list and done
      during this refit. I will wait to see how much I have to adjust it.
      On 7/8/2013 8:23 PM, John Stevenson wrote:
      Pete,
    • #79801
      I agree with John. They both do the job. Silverheels came with a stuffing
      box. When I re-powered, the installation mechanic offered to throw in a new
      PSS for free – I guess he had a bunch on the shelf – so I said sure, do it.
      Otherwise I’d still have the original stuffing box. No big deal either way.
    • #79802
      How’s the weather down there?
    • #79805
      Installed a PSS unit when I was hauled for a bottom peal and seal. This was 5 years ago. No problems and dry as a bone. This was the newer “spring” model.
      Keehi Lagoon, O’ahu
    • #79806
      Keehi Lagoon, O’ahu
