Hello all,
I’m trying this post again now that the e-mail may be functioning. Received no responses before, which I’m pretty sure is due to no one seeing it.
I’m about to pull the trigger on a flex-o-fold prop for Blue Moon. I currently have the standard fixed pitch 3-blade, 20″, with 13″ pitch, Columbian style ‘E’ (I have no idea what this last part means) which appears to be the original set up from the factory. I think a lot of you are running 19″props (vice 20″) nowadays. Any advice on prop size/pitch? BTW, I have the Westerbeke W58. Thanks!…
David Tye
Blue Moon, #189
