Forums › General Discussion › Original Propeller size?
- This topic has 5 replies, 4 voices, and was last updated 6 years, 11 months ago by
Discoverie.
March 10, 2018 at 10:13 am #224001
ModeratorAll,
I’m in the middle of a repower to electric and I just found my first “goof” (of many, I’m sure). We based the gearing of the system on the original propeller specs of 20 x 13. However, I got mine back from the prop shop yesterday and it’s an 18 x 11. That’s a pretty significant difference.So two questions:
1. What size do you all have (if yours is original)?
2. If the original was, in fact, 20 x 13, do any of you have one you’d like to sell?Thanks,
Revery #219 -
March 10, 2018 at 2:16 pm #224003
ParticipantOur original was 20X13, same as listed in the 424 sales brochure. I always had the impression we were somewhat over-propped. WOT gave us somewhat less than the spec 3000 RPM, and a lot of black smoke. We changed to a 18X11 flex o fold, and it seems to be about right. Certainly not too weak. However, I was cautioned by flex o fold to not compare their prop to other props vis a vis the diameter and pitch. No usable correlation.
Yes, I do have my original prop, but I am holding onto it in case I have a prop crisis in some remote location. Sorry can’t help there.
Blue Moon -
March 10, 2018 at 2:47 pm #224004
ParticipantProp size selection is a function of the torque and speed of the engine that drives it and the gear reduction of the transmission and V-drive and of course the boat displacement and hull shape. Not all power plants work the same. I doubt that an electric motor would work well with the original prop. I suggest that you contact a propeller manufacturer and ask for their help.
March 10, 2018 at 5:42 pm #224006
ModeratorThanks gents.
Rich, roger on all of that and, if I were designing the powertrain, I’d definitely reach out to a prop manufacturer. But the reduction gearing was sized by the motor system manufacturer based on hanging a 20 x 13 behind it. And I trust their engineering skills.I may not have been clear in my original questions. The original size is actually a moot point but I asked anyway to ease my conscience…I didn’t make sure what I had attached (boat was in the water) before the system was designed. Mea culpa.
So really, the only question I “really” have is “Does anyone have a 20x13LH for sale?”
Cheers,
Revery #219 -
March 11, 2018 at 8:48 pm #224007
March 11, 2018 at 8:53 pm #224009
ParticipantPic of 18LH11 mentioned above
