Forums Announcements oil temperature and water temperature sender
Viewing 1 reply thread
    • #224527
      Rock Richardson
      where would i find or locate the oil and water temperature on my 58w westerbeak engine the wires are cut not sure where to look
      thanks
      rock
      sv topaz
    • #224528
      There is no oil temperature sensor on the W58. There is an oil pressure transmitter and a low oil pressure transmitter (for the warning horn/bell). Both are located on the left side of the engine (starboard side of the boat). The water temperature sensor should be on/near your thermostat housing.
