Forums General Discussion New spreader lights bring day to night
Viewing 15 reply threads
    • #68919
      Hi All,
      I just put these lights up, and they draw 1/2 of the old festoon lights
      power with the obvious result. These lights as marine lights: $109. The
      exact same lights with the exact same specs on Amazon, $20. Difference?
      These are black for off road/rv use. Yacht ones are white. Do I care?
      Not much.
    • #81016
      Bob,
      Wow! How much do they draw?
      I mounted a pair of 55W sealed beam lamps under the main spreaders when I re-wired the masts back in 2007, one fixed aiming straight down and one swivel aimed at the foredeck. At that time they were about $9 and $18, respectively, Port Supply prices. They draw 4.6A@12V apiece. I don’t use them often, but when I do they’re a godsend. Mainly they’re for complex deck chores offshore at night, and for lighting up the boat for sleepy watch keepers on approaching ships.
    • #81017
      Tor, they are 18 watts a piece, or 1.5 amps at 12v. I’m going to separate
      the mizzen fron the main so in your case, with the main only, 3 amps.
      phone.
      On May 28, 2014 7:40 AM, “Silverheels” wrote:
      Bob,
    • #81018
      As I suspected. A much kinder amp draw, for sure, and
      so bright! Well done. I rarely use mine, drawing 9+amps
      together, without the engine running.
    • #81020
      I replaced mine with a pair of marine LED deck-lights, not spreader lights. They draw .4A. They are nowhere near as bright as what you show but they are adequate and don’t even deflect the ammeter when they are on. At $56ea, they are affordable and much less expensive than the LED spreader lamps. I have no idea why the spreader lights are so much more expensive.
      http://www.defender.com/product3.jsp?path=-1|65136|2312533&id=1845652
      They swivel, which is not a feature for a spreader light. The headsail can press against the light when tacking. This will push the lamp back on its swivel, illuminating the cockpit and not the foredeck. I cut a small piece of aluminum angle bracket and attached it to the mounting base. This holds the lamp from swiveling.
      The original deck lamps from Pearson were junk. They ate bulbs and sucked down battery power when they worked.
    • #81021
      I rarely use mine as well because of the 7 amp draw. Now with three for
      each mast, I’ll be happy to use them regularly. I may even add a remote
      control (did for a customer) so that while tooling around an anchorage I
      can turn them on as I approach the boat.
    • #81022
      These lamps, Rich, are off road version of the marine ones – same
      construction specs – and were $20 each. With six large LEDs each they can
      do some lighting. They can be moved, but were tightened in place.
      Moreover, because they fit completely under the spreader I think they’ll be
      out of the way of the sails.
      At least that’s the plan…
      expensive.
    • #81026
      I made a little clip-bracket to hold my one swivel
      spreader light, too, to keep it aimed onto the
      foredeck. Otherwise just sailing the boat would
      re-direct the light, invariably towards someplace I
      didn’t want it to shine. There is no provision for
      tensioning the swivel, a simple ball joint.
    • #81033
      Bob,
      Interesting solution, but if I don’t pay top price for marine quality, I’m not going to be satisfied (what am I saying, someone please whack me on the back of the head).
      The spotlights I mounted were clear under the spreaders too, but the headsail still pushed them back when tacking. If your headsail is smaller than your foretriangle you may not have this problem. The fix was pretty simple, just a short section of L-bracket mounted under the lamp using the same faster that was used to hold the lamp. This prevents the lamp from swiveling back.
    • #81034
      Rich, normally I’d agree with you, but in this case the only difference
      was color. Really, the specs were identical in every way.
      The bracket on these lights are designed such that they can rotate in only
      two axis, with one the bolt through the spreader and one parallel to the
      light.
      Even my 135 won’t hit them, I think although I could be wrong.
      We’ll see. One thing I will do, however, is separate the mizzen from the
      main so that I only have to light one set at a time.
      phone.
      On May 28, 2014 5:25 PM, wrote:
      Bob,
      back of the head).
      swiveling back.
    • #81040
      cstewart
      I have been thinking about replacing my spreader lights with LED but frankly, that has been a low priority. I have already replaced everything filament with LED including running, anchor, and all cabin lights. The two that I haven’t done yet are the steamer and the spreaders. My logic is that I only use them when the engine is running so the amperage doesn’t matter. At anchor, I have on lots of cabin lights with the anchor light and I barely move the amp needle.
      Doing a night crossing the LED running lights save about 8 a-hrs/ hr.
      Now if I just had LED refrigeration, radar and autopilot.
    • #81041
      Somehow I missed the web link for those lights. Bob could you resend that please.
      On May 27, 2014, at 9:23 PM, Robert Fine wrote:
      Hi All,
      Not much.
    • #81043
      allantereshko
      I couldn’t find the link,also. If you would be so kind as to resend.
    • #81047
      Here you go:
      http://www.amazon.com/18w-LED-Spot-Work-Light/dp/B00AZPI0NE/ref=sr_1_6?ie=UTF8&qid=1401447507&sr=8-6&keywords=led+off+road+lights
      phone.
      On May 30, 2014 8:46 AM, “allantereshko”
    • #81055
      allantereshko
      Thanks,got a couple from Amazon. Many potential applications. How did you wind up switching them?
    • #81056
      I’m going to switch them so that I can light the main, mizzen or both. I
      just haven’t figured out the best solution to that yet.
      On Sat, May 31, 2014 at 7:58 AM, allantereshko <
