Forums › General Discussion › nav light questions
- This topic has 2 replies, 2 voices, and was last updated 16 years, 11 months ago by
john stevenson.
March 30, 2008 at 5:30 pm #66890
ParticipantTor,
I replaced the bow running lights with a bi-color light on the rail last year. I used the standard rail mount for it so it will get crushed if I ever run the bow pulpit into something hard, but it is more likely I'll bash it with the anchor before that happens. I think the only safe place for the lighs is on the forward stantions, but then you're talking about 2 separate lights.Pics and description at http://www.svsarah.com/Sarah/ewUpgradeDeckRig.htm
You have to scroll way down toward the bottom of this page to Bow Running Lights and Bow Rail Re-bed.I currently have an incandescent bulb in this light as I use the deck lights only when motoring. It is an Aqua-Signal light so I believe DrLED would have an LED (if Pete's company doesn't have one). They may not have an LED for the model 25 light I used, it is likely they only have them for the larger model 40 and 41 lights. I replaced the incandescent bulbs in my tri-color with DrLED bulbs last year.
So I know you can get LED bulbs for the larger Aqua-Signal lights, but I'm afraid the combination of the light and the LED bulb will put you well over $100.John
On Sun, Mar 30, 2008 at 1:06 PM, Silver Heels < ([email][/email])> wrote:
Time to replace the original port-starboard running lights on Silver Heels. My thought is to extend the existing forward
running lights' wires up through the mast pulpit and mount a bi-color nav light on the rail. Would like to use a pulpit
rail mount for that, somehow reversed so the light fixture is a few inches abaft the bow pulpit's leading edge rather
than sticking out in front of it – so it's not necessarily the first thing squashed next time I nudge a piling.My first question is, has anybody come up with a better mounting idea? (I already have a masthead tri-color. This light
is for motoring, and maybe sailing in close quarters.)My second question regards LED, which I'd prefer. West Marine offers a simple #2984 Hella bi-color with 25W incandescent
bulb (2 n mi visibility) for $63.99 retail. The LED bi-color lights are more than 4X that price. Is there an LED bulb
made to (or that can be made to) replace the 25W incandescent bulb in the Hella light socket. Barring that, is there
some other way to wind up with an LED bi-color light forward for under a hundred bucks?Thanks,
No virus found in this outgoing message.
Checked by AVG.
Version: 7.5.519 / Virus Database: 269.22.1/1350 – Release Date: 3/30/2008 12:32 PM
March 30, 2008 at 5:58 pm #69348
Rich wrote:
Regarding the LED nav lights. If you have a masthead tricolror, why bother
with LED lamps on your deck lamps? Power savings from running the LEDs is
of little value if the engine is running. IMHO, it would make more sense to
invest in an energy efficient masthead.I think Rick is indeed right regarding the power consumption. The real
benefit with a GOOD led bow light is reliability. I don’t know how many
times I have found myself fiddling with incandescent units to get them
to light.Now to what John said, SCADtech previewed the VERO Navigation Lights at
the Miami boat show. This unit is tiny so less chance of getting caught
on anything. It is designed for utter reliability. For example, it
comes with a 12′ lead wire so you can make the first connect well below
deck, in a dry area where the connections will not corrode or get
snagged. It is still a few months before these ship, but they are
really the cat’s meow in LED lights and the price will make all the
other units out there look silly.In addition to the bow light, the same form factor will be available for
a steaming light and a stern light.I send around some photos or a link soon.
And here is some trivia with which you can impress your friends and win
bets in bars… Where does the name “VERO” come from?Stay tuned.
J
Post generated from Pearson424 Forum using Mail2Forum -
March 30, 2008 at 8:37 pm #69349
ParticipantTor,
Sounds like a good, protected location for the light. Wish I’d thought of it.
I agree you should be able to get the pulpit stanchion clear of the cap rail enough to drill the hole and run the wire for the light. You might consider removing all the stanchions while you’re at it and check the bedding. My pulpit had no bedding under any of the stanchions – the source of a leak in one of the forward cabin lockers. I did it without totally removing the pulpit – just did one side a time.John
