Forums General Discussion Mixing elbow Westerbeke M60
Viewing 10 reply threads
    • #221877
      cstewart
      I just noticed a leak in my mixing elbow this afternoon and was smelling diesel exhaust in the cabin. When I pulled the insulation off, the elbow crumbled in my hand. I have a Westerbeke M60. I assume some of you guys have had to replace this at some time, and wondered if this is a standard part that I can buy anywhere, or is it a hard to find M60 part. Also the pipe going into the exhaust manifold (about 1.5″ X 6″ threaded pipe) is thoroughly rusted and I am afraid that if I put a pipe wrench on it, it will break off in the manifold. Any help or suggestions, please. Thanks,
      Charlie
      OneEighty #54
    • #221880
      Charlie,
      Do you mean W60?  I don’t know what an M60 is.
      The elbow on a W60 and probably most Westerbeke engines is a standard water injection elbow available at most marine retailers such as Defender.  Getting the damn thing off can be a challenge however.  Try a long pipe-wrench with an extension on it and remove the whole black-pipe.  Discard and replace the pipe.  The injection elbows only last about 15 years or so and can restrict water flow when they rust causing the engine to overheat.
    • #221882
      Silver Girl
      Try this: http://www.tadiesels.com/exhaust-elbows.htm.  Ref # EE24 – 486.
      I have personally used — successfully – this product.  It is identical to the original.  ..Robert
      sam
      S—-Original Message—–
    • #221884
      cstewart
      Thanks, guys. I was able to find the Westerbeke part through my local marine supplier (Saunders Marine) and there was only one on the shelf at Westerbeke. Part # 33067. I ordered it and although I thought it was expensive ($230) it is much less than the same part for my old Volvo. Looks like you could make one up with 1.5″ pipe from the hardware store for $25. Has anyone done that? My problem now is getting the old 6″ pipe screwed out of the manifold. I have PB Blasted it, heated it, frozen it and put an 18″ pipe wrench on it. No movement, and starting to warp the pipe. I think I will soak it for several days in PB Blaster and see if that helps. Are there any magic tricks I haven’t tried? Worse case, I think I could perhaps use the old pipe as a nipple and connect the mixer elbow with heavy exhaust hose and clamps. My biggest concern is that I don’t break the old pipe off in the Manifold.
      Thanks for your feedback. Mine never stopped up, it just corroded severely under the insulation wrap, and I never saw it.
      Charlie
      OneEighty #54
    • #221885
      markscheyer
      I took mine to a machine shop when I gave up.
      Mark Scheyer
      713.861.0847
      Sent from my T-Mobile 4G LTE Device
      ——– Original message ——–
    • #221886
      cstewart
      For anyone else who has the same problem with the W60 here is the catalog pic for the mixing elbow.
    • #221891
      That is one gnarly collection of oxides.  I suspect mine (pic attached) was a more recent replacement on my W58. But, based on your picture, I do wonder what’s under the insulation. My picture is collateral from my recent efforts to replace the lift muffler. And yes the coolant overflow line needs to be secured.
      Roger
    • #221905
      cstewart
      I finally got the pipe out of the manifold using heat, cool, 18″ pipewrench, a bigger hammer and someone who knows what to do. My mixing elbow is now replaced and like new. Can you believe that now I have a new problem. While testing the engine and leaning over it, I can hear the fresh-water-pump bearings singing to me. Not a good song.
      I know most of you don’t still have the old M60, but almost all of you know lots of stuff about them. Can someone give me any comforting news that I may be able to find a fresh-water-pump or parts for rebuild for this W60 beast. Im at a loss, and afraid of what I am reading about their scarcity. Does anyone have a part number for pump or kit?
      Charlie
      OneEighty #54
    • #221932
      Hi Charlie,
      The pump can be rebuilt.
    • #221937
      I should have mentioned that Bob Fine is the other part of “we” as in we replaced the fresh water pump as spring. “We”…er…Bob actually replaced most of the heat exchangers as well as the raw water pump. His advice in this area is priceless.
      tkx,
      rb
    • #221938
      Lawrence Michaels
      Hello Charlie, I found out myself you can`t buy a rebuild kit. A friend of mine had to hunt around for different h2/o pumps and peice it together to rebuild one.  Westerbeke sells new ones for $900.00 . Call to check it out.     Good Luck !
