Forums General Discussion Mast Tangs
Viewing 20 reply threads
    • #69052
      Has anyone replaced their mast tangs (for example while replacing the
      running rigging)?
      If so, is there a stock source of these tangs or has anyone made some
      engineering drawings of them so I can machine a new set before I take
      the old ones down?
    • #82102
      (make that standing rigging…a little fatigued after the rigging
      inspection).
      running rigging)?
      the old ones down?
    • #82103
      Hi Pete,
      If I recall the tangs for the shrouds are just flat SS stock, bent with a hole on each end. I’ll be out at the boat tonight and the mast is on a rack so will look and take pictures and measurements if you like.
      I replaced everything in my running rigging [sic] except the tangs. 😉
      I looked at them and didn’t see any corrosion or cracking so thought I would leave them for now. Also worried it might be opening a can of worms to replace them. The lowers port to stbd are through bolted to the mast and I’m wondering if there is a sleeve around the bolt inside the mast to prevent compressing the aluminum under load. If so one would have to be really, really careful replacing the tangs because I can think of no way on earth to replace that sleeve if it dropped off.
      Have you looked at that detail?
    • #82104
      I think the compression tubes are normally the full length of the OD of the
      mast section. That is the holes in the mast wall are the same diameter as
      the OD of the tubes. That way all of the compression force of the through
      bolt and nut is on the tube not the mast wall. That’s how they were on my
      previous boat. I also have not removed the tangs on the 424 to see if it
      is the same.
      Sarah’s Blog
      On Mon, Feb 23, 2015 at 5:14 PM, Skip MacElhannon via maillist <
      > wrote:
      Hi Pete,
    • #82105
      That makes sense.   Otherwise how would Pearson get them in to begin with.
      Will try to  check that
      Sent from my Verizon Wireless 4G LTE smartphone
    • #82106
      The compression tube length is the width of the mast minus one wall
      thickness. The hole on one side of the mast is the size of the bolt.
      The hole on the other side is large enough to pass the compression tube
      through.
      is the same.
      Sarah’s Blog
      > wrote:
      Hi Pete,
    • #82107
      The problem is that they used an aluminum tube for the compression tube
      and it corrodes to the bolt.
    • #82109
      When I gave Silverheels a staysail, I also added running
      backstays. These, of course, required tangs on the mast, which I
      made as skip describes below. I don’t recall now exactly how I
      dealt with the compression tube, but I did insert one. As for the
      angle, as long as you get it reasonably correct the tangs ill
      work as intended. If it’s slightly wrong, the tang strap will
      simply adjust itself. How could it not?
    • #82108
      cstewart
      gee thanks guys. Just when I think that I have my boat in great shape (just spent a fortune on the hard) you give me something new to worry about. And I thought Tang was a breakfast drink.
      Charlie
      OneEighty #54
    • #82110
      Not to worry, Charlie. Just inspect all the boat’s tangs very
      closely, literally with a magnifying glass, for stress cracks or
      corrosion. If you’re not 100% sure, get some of the dye riggers
      use for that, which shows up tiny cracks so you won’t even need
      the magnifier. If they’re suspect, Pete will (soon) be able to
      tell you exactly how to replace them.
    • #82111
      cstewart
      Pete is running out of things to replace. If he replaces the hull, can he still call it a Pearson?
    • #82112
      That is the sad truth…
      Andre Gide 1869-1951
    • #82113
      Start of attached email. Subject: Re: Mast Tangs
      Time to sell it and start over!!!!!!!    :-]
    • #82114
    • #82115
      Re: Mast Tangs
      Author:
      Silly question.  I’ve owned the boat and sailed her for 6 years now, but never found out what the tang on the mizzen is for.  This discussion brought it to my attention.  I’m sure I’m missing something here (the Admiral always says I have tunnel vision).
      Keehi Lagoon, O’ahu
      Reply Link:
    • #82116
      What tang, Dan? Where on the mizzen mast? I expect we all have upper & lower tangs for the upper & lower mizzen shrouds.
      Captain Tor Pinney
    • #82117
      The tang on my mizzen was on the forward facing side. It had a cable attached that you could use on the main boom as a lift. So that you didn’t have to rely on the topping lift to keep The boom up while at the dock or at anchor.
      Captain Tor Pinney
    • #82118
      Re: Mast Tangs
      Author:
      The tang on my mizzen is forward facing and about 3 feet below the spreaders.  It never had a cable/line attached since I bought the boat.  Maybe Alan’s right in that it is dock backup for the main topping lift.  Never thought of it that way, but never knew there was a need for a secondary topping lift.  This is the only tank on either mast.
      Keehi Lagoon, O’ahu
      Reply Link:
    • #82119
      I use that tang for a block and tackle that are always rigged as an MOB
      lift but mostly use it as “remove before flight” support of the aft end
      of the main boom. This seems to quiet things down in rolling
      anchorages. (we have a garhauer solid vang and no topping lift, but
      this line pulls against the main sheet and keeps the boom pretty still).
    • #82120
      Here is a picture of a “tang” connecting shroud end fitting to mast.
      Your boat perhaps does not have the red oval.
      On 3/1/2015 5:34 PM, dan.kalinowski— via maillist wrote:
      Re: Mast Tangs
      Author:
      Keehi Lagoon, O’ahu
    • #82121
      cstewart
      That mizzen tang thang was something I had meant to ask the forum about. I for the life of me could not figure out what it might have been for. Ive never used it, it just sits there. Now that it has been suggested that it was for lifting the main boom, it makes sense. Pearson must have liked that concept, for on my previous P323, they had swedged a 3 foot cable off of the backstay and put a snap shackle on the other end for holding up the boom. I never used it either.
      Charlie
