Forums › General Discussion › LEDs for Aft and V-Bearth Lights
- This topic has 17 replies, 9 voices, and was last updated 14 years, 11 months ago by
john stevenson.
February 24, 2010 at 4:24 pm #67933
Indulgence
ParticipantHello,
Does anyone have a suggestion for a LED replacement bulb for the Aft and v-Bearth halogen lamps? I don’t want to replace the lights…just the bulbs. Thanks.
February 24, 2010 at 4:30 pm #75009
SpectatorCheck out Dr LED that’s what I used.
On Feb 24, 2010, at 8:24, “Indulgence” wrote:
Hello,
John Sommer
Indulgence #179
Portland, ME_______________________________________________
https://pearson424.org/mailman/listinfo/maillist_pearson424.orgPost generated from Pearson424 Forum using Mail2Forum
February 24, 2010 at 5:00 pm #75010
ParticipantNo question…. use the sensibulb from sailorsolutions.
I tested a lot of them… and they are the only ones that the color, yes color, is pleasing enough to READ by.
Mention that you are a 424 owner and you get a discount.
just a hppy customer.
alan— On Wed, 2/24/10, Patrick wrote:
February 24, 2010 at 5:00 pm #75019
February 24, 2010 at 9:45 pm #75026
So on my PDA your number truncated.
February 25, 2010 at 12:11 am #75011
Syringa
ParticipantI got two of these lights last year for my bell reading lights and love them. I just got two more http://cgi.ebay.com/ebaymotors/New-12V-White-G4-Led-Light-Bulb-Warm-White-Back-Pins_W0QQitemZ150413316838QQcmdZViewItemQQptZBoat_Parts_Accessories_Gear?hash=item23055512e6
I also just ordered three of these lights for the over head lights should be here in the next few days if I like them I also pass that infor on.http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=130368806584&viewitem=&sspagename=STRK%3AMEWNX%3AIT
February 25, 2010 at 12:11 am #75027
Syringa
ParticipantI got two of these lights last year for my bell reading lights and love them. I just got two more http://cgi.ebay.com/ebaymotors/New-12V-White-G4-Led-Light-Bulb-Warm-White-Back-Pins_W0QQitemZ150413316838QQcmdZViewItemQQptZBoat_Parts_Accessories_Gear?hash=item23055512e6 I also just ordered three of these lights for the over head lights should be here in the next few days if I like them I also pass that infor on.http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=130368806584&viewitem=&sspagename=STRK%3AMEWNX%3AIT
Don Gardner S/V Syringa #124 /)+/)+~=:)
m2f
Read this topic online here: https://www.pearson424.org/bb2forum/viewtopic.php?p=7020#7020
m2f
Post generated from Pearson424 Forum using Mail2Forum -
February 27, 2010 at 2:18 am #75012
Syringa
ParticipantI got my lights ion today. I did a test with the old lights and the amp draw was 2 3/4 amp for 6 lights. I got about the same light and it’s draw is now about 3/4 amp. To say the least I am Happy.
February 27, 2010 at 2:18 am #75032
Syringa
m2f
Read this topic online here: https://www.pearson424.org/bb2forum/viewtopic.php?p=7021#7021
m2f
March 29, 2010 at 9:47 pm #75020
ParticipantDon
How did you adapt the bulbs to the screw in type bases? The link takes me to lights with two pins on the back. Is there an adapter or do you solder them into an old bulb base?
Linus -
March 29, 2010 at 10:47 pm #75099
SpectatorLook here: they have the bayonet (cylinder with two nubs), two pin (halogen
replacement), and traditional screw in type replacement bulbs:
http://www.doctorled.com/p2.htm-p
On Mon, Mar 29, 2010 at 2:47 PM, sumocean wrote:
Don
Linus_______________________________________________
March 30, 2010 at 2:01 am #75021
Syringa
ParticipantLinus
None of my bulds have screw bases. I got the bulbs that fit the sockets on each light.
Don
March 30, 2010 at 10:50 pm #75022
Indulgence
ParticipantHello,
I’ve been having some issues post to the list:
I have put up a picture of the bulb I am trying to replace….is this the
same bulb that you found a replacement for…look at that light bulb here:I have not been able to find an LED with similar dimensions. Suggestions?
April 1, 2010 at 6:02 am #75104
SpectatorThat is a bayonette type bulb. Can you send a pic of the fixture as well.
On Tue, Mar 30, 2010 at 3:50 PM, Indulgence wrote:
Hello,
John Sommer
Indulgence #179
April 1, 2010 at 12:50 pm #75105
ParticipantThese are small spot lights that were original equipment over the head of
the aft bunk and on each side of the berth in the forward cabin. They have
a bayonet base, but the throat of the bulb is much longer than a standard
bayonet bulb of the same base diameter. So those DrLED bulbs will not fit
the fixture. I’ve looked for years for a LED replacement with no success,
so I’ll be really interested if someone has found one.
These are difficult to find bulbs even in the incandescent form, although WM
does stock them (usually requires an order against the warehouse).
If you want to go LED, I think the only option is to replace the fixture
with one designed for LED or designed for one of the standard bulb
configuration for which there is a readily available LED (e.g., halogen
G4). I did replace the fixtures in the forward cabin with ones designed for
LED, but they give very poor light. It’s a difficult location to put an
effective reading light, which is what I assume the spot light was intended
for. So I’m still looking for a LED-ready fixture that will work in that
location.On Thu, Apr 1, 2010 at 2:02 AM, Patrick “Peaboy” Walters <
> wrote:That is a bayonette type bulb. Can you send a pic of the fixture as well.
Hello,
same bulb that you found a replacement for…look at that light bulbhere:
Suggestions?
John Sommer
Indulgence #179
April 1, 2010 at 1:04 pm #75106
ParticipantNot that this addresses the issue, but a local marine store sells the same fixture and has replacement bulbs. I think its old stock.
I replaced the two fixtures above the aft bunk last year because they didn’t work well. I’m considering LED replacements and would also be interested to hear if someone comes up with a solution. I also have one in my nav station.
April 1, 2010 at 3:29 pm #75107
ModeratorHi John,
Those spots can use the Dr LED bulbs – I use them in mine – all you have to
do is shave a bit off the circumference of the bulb and it fits in. The
tough part is having enough friction with your fingertips to allow you to
turn the bulb.Bob
WM
for
wrote:
Hello,
the
here:
Suggestions?
John Sommer
Indulgence #179
April 1, 2010 at 3:33 pm #75108
ParticipantThanks, Bob – that’s good to know.
On Thu, Apr 1, 2010 at 11:29 AM, Robert Fine wrote:
Hi John,
turn the bulb.Bob
On Thu, Apr 1, 2010 at 8:49 AM, John Stevenson <
the aft bunk and on each side of the berth in the forward cabin. Theyhave
bayonet bulb of the same base diameter. So those DrLED bulbs will notfit
success,
WM
for
effective reading light, which is what I assume the spot light wasintended
well.
wrote:
Hello,
the
here:
Suggestions?
John Sommer
Indulgence #179
