Don’t know if any 424 crews are or will be passing through the Jacksonville FL area but my old Hooka Rig is available…and cheap! Bought the tank before leaving for the Pacific in 2008, at which time I also had the Sherwood regulator rebuilt. It has a 40′ hose and I just kept everything in a cockpit locker. Time to clean the bottom? Tossed the hose & regulator over the side, never had to budge the tank, and away I went to clean the bottom. All done? Coiled up the hose, washed out the regulator if fresh water was available. Anchor snagged on something? Put tank & hose in dinghy to go have a look. Very easy system. To get a fill in Australia, I had to have the tank hydro’d, which was done November 2010. Since then, it’s been empty & sealed. You can find pics here: https://goo.gl/photos/3fkDwQwr4Xnn992g8
How about $100?
Jack 727 772 3002 or jack_patricia@yahoo.com
