Hello Dan,
You may want to move this post to the General Discussion area, vice the Announcement area.
If your experience is like mine, the leak you are experiencing may be at the top of the tank, where the vent fitting is located. I cut a hole in the sole (just above the vent fitting, and under the main cabin table) and built a flange to fit the piece I cut out…so I could have future access to the area. I resealed the vent fitting and that resolved my problem.
I ultimately wanted more holding tank capacity than the 20 gallons afforded by the existing tank. I also needed to fix/rebuild the cabin sole, including jacking it up/reinforcing where it had sagged. So wound up cutting the floor out and designing a custom holding tank with flared sides, increasing our capacity to 37 gallons. Has worked well for us for several years and hopefully will for the foreseeable future. Obviously this sort of tank cannot be removed unless the cabin sole is removed, so this was a roll of the dice. Has paid off so far. The tank was made to my specifications of plastic by Miller Plastics.
