Forums › General Discussion › Genoa size
- This topic has 20 replies, 9 voices, and was last updated 11 years, 4 months ago by
Ted Elaine.
October 10, 2013 at 12:39 am #68800
Adam
ParticipantI currently have a 155% genoa on roller fuller, and considering new headsail. Sailmaker recommends 135% instead of 155%. What do you all have and like?
Adam
October 10, 2013 at 12:52 am #80175
ModeratorI have a 120% and a staysail. I’d like a 130-135%. The boat goes ok as
is, though. If you do get a new headsail, make sure the clew is not so
high that you can’t flatten or shape it. I think a 155 is too big.Bob
and like?Thanks
Adam
October 10, 2013 at 1:51 am #80176
ParticipantAdam,
Do you have a ketch or a cutter? I have a 135 Genoa on my ketch, and it is
as large an overlap as I would want or could set. I suspect you have a
cutter, which might be able to set a 150 as the mast is further forward.
Also the decision must be based on the area in which you sail. If I were
to go trans-ocean again I would opt for a 120. Much of the time off shore
I sailed with the genoa partially furled to about a 120. On the Chesapeake
Bay I was glad I had the larger Genoa.Regards,
headsail. Sailmaker recommends 135% instead of 155%. What do you allhave
and like?
Adam
October 10, 2013 at 2:11 am #80177
ParticipantIMHO, a 135% is the best compromise.
October 10, 2013 at 2:11 am #80178
ParticipantGood points, John, but isn’t the mainmast on a cutter rig stepped further
aft than on a ketch?Tor
Original MessageQuote:Post generated from Pearson424 Forum using Mail2Forum
October 10, 2013 at 2:40 am #80179
Adam
ParticipantI have the ketch rig and sail on the Gulf coast.
At times glad I have the 155, put other times I could do with less.
Also have a small jib (90%?) in new condition in a locker down below.Adam
October 10, 2013 at 2:53 am #80180
ParticipantTor,
you are correct the cutter rig mast is further aft, making a 150 an even
larger sail.
October 10, 2013 at 3:04 am #80181
hanks424
ParticipantFor summertime in light-wind S. Florida coastal waters my 150% balances well jig and jigger — I love it. In the winter and during 20+ winds my 80% works great. Have used the 150% reefed in a pinch. Exclusive blue water I’d probably add a 135% to my inventory.
Like others have stated, it depends on when and where you play.
Hank S.
Shay #80________________________________
October 10, 2013 at 3:07 am #80182
ParticipantAdam,
Seems like a 135% genoa plus a staysail will approximate the square footage
of a 155% jenny. Granted, the 155 will probably be more effective in light
airs, but the 135/staysail combo offers a variety of all-weather sail
options right down to a storm jib.Food for thought.
October 10, 2013 at 3:11 am #80183
ParticipantAdam,
Why not buy the new 135% genoa and keep the old 155 for light air sailing?
There’s ample space for it in one of the cockpit lockers.Tor
October 10, 2013 at 2:15 pm #80184
ParticipantOr cut-down your old 155 and buy a new one. I sail with a 155 here in the northeast. My boat is a sloop, the same dimensions as the tall ketch but without the mizzen. Our summer winds are typically light. In anything up to about 20 kts apparent, the 155 is needed. With 10 kts apparent, even more sail would help. I just ordered a new 155% genoa ($5K). I ordered it from Doyle. I ordered heavy fabric for the headsail, the same weight as my main. My practice is to depower the main when the wind picks up and not reef the headsail. If this doesn’t work, I roll-up the headsail and sail with just main. I don’t reef the main for coastal cruising. Reefing the headsail doesn’t seem to work well unless I’m off the wind. The mast, even with the taller rig, is short for the boat. It’s like leaving the mooring with a reef in already.
The boat points just fine with a 155%.
October 12, 2013 at 3:04 am #80185
ParticipantI have a 135, which works well with the constant strong trades here in Hawai’i. I also have a (I guess you would call it a) spinnaker the PO had made for the mizzen. I have yet to fly this. Does anyone else have this sail?
If so, what is your experience/advice?Dan Kalinowski
Keehi Lagoon, O’ahu -
October 12, 2013 at 3:18 am #80186
ParticipantDan,
Sounds like you have a mizzen staysail. It’s a sail I’ve long wanted to
add to Sarah’s inventory. Jack & Patricia Tyler had one on Whoosh and used
it often. Here’s a picture of Whoosh sailing under mizzen staysail in
Caribbean:
http://www.svsarah.com/Sarah/Images/Whoosh%20Mizzen%20Stay%20Sail.JPGRegards,
sail?
Keehi Lagoon, O’ahu_______________________________________________
October 12, 2013 at 12:30 pm #80187
ParticipantAloha John: Always a sloop sailor before my ketch (but certainly sold on the ketch rig) , I never knew what to call this sail. Interestingly, mine is green and white striped in the same pattern as the one on Whoosh. Looking forward to finding out what this thing does. My boat was the Cruising World Calendar cover girl for 1990 and the pic shows the sail flying brightly.
Mahalo
October 12, 2013 at 3:22 pm #80188
ParticipantDan,
I learned to fly a mizzen staysail on a yawl I used to own, so was happy to
find one aboard Silverheels when I bought her. I’ve only used it maybe 10
times, usually on long offshore legs. It’s fun to do, looks cool, and gives
the boat an extra ½-1 knot. Typically flown when reaching in light airs, it
fills the large gap between the boomed out main and mizzen sails. It may
take a bit of experimentation to decide where to attach the tack on your
boat, but you can usually hold that corner in your hand while the sail is up
& full and move it around to create the best sail shape. I tether mine
either to the aft foot of the windward mast pulpit, or to a deck padeye to
which a staysail sheet block is normally shackled (photo attached).There should be an external swivel block at the mizzen masthead for the
mizzen staysail’s halyard, and a cleat on the port side of the mizzen mast.
The single sheet is led outboard of the mizzen shroud to another swivel
block on the end of the mizzen boom (which may be secured out to leeward
with a preventer if necessary, and from there to a cleat on the side of the
mizzen boom or else to any handy cleat on the cockpit combing (photos
attached).I found the attached sketch on Google. Looks like an old Bruce Bingham
drawing! The instructions originally said “(Mizzen) running backstay set up
to leeward quarter,” but I’m sure that’s wrong so I changed it to say
“windward.”Have fun,
October 12, 2013 at 9:56 pm #80189
Adam
ParticipantThanks for all of the help! Seems like the majority of you like the 135 %.
Never thought of cutting the 155 down to get a smaller sail, great idea! Wondering if Shay or anyone else has done the Isla Mujueres race, and what was needed. My current sail is in ok condition, but has lost it’s shape and doesn’t point as well. Also have a roller furling main, and understand some loss of some sail area. I do use my mizzen staysail at times as Tor described, but I sure could have used that great diagram and pics years ago!
Adam -
October 12, 2013 at 10:49 pm #80190
ParticipantThanks for the pix and diagram Tor! This mizzen staysail looks like fun and I look forward to flying it once all this damn rain moves on. Flood watch for windward O’ahu for the next day.
October 12, 2013 at 11:10 pm #80191
hanks424
ParticipantAdam, Mack Sails built my genoa and we had a similar discussion. Decided to keep up the tradition and stay with the 150% since most of our treks have been coastal during the summer. As I mentioned before, a 135 is an ideal ‘universal’ size, but light winds are common for me. When the wind picks up, we douse the genoa and run a (full batted) reefed main. 90% of the time I run jib and jigger.
Hank S.
Ketch Shay #90
(currently scratching my head wondering why I’m selling her)________________________________
October 13, 2013 at 12:48 am #80192
On HiFlite we put the 150 in storage and just use the 135. Our local
sailmaker said not to try cutting sown the 150, he didn’t think we would
be happy with it. Our mizzen staysail was embarassing to use (pink,
orange, lime green and blue) until I got a picture of what it looks like
from a distance. We love it and it turn a lot of heads as we sail on.
We enjoy calling out the order “Hoist the mizzen staysail.”On 10/12/2013 5:56 PM, Adam wrote:
Adam_______________________________________________
No virus found in this message.
Checked by AVG – http://www.avg.com
Version: 2014.0.4142 / Virus Database: 3604/6742 – Release Date: 10/11/13_______________________________________________
October 13, 2013 at 12:36 pm #80193
Could one of you folks who have a mizzen staysail please take luff,
leach, and foot measurements? Those of us who are staysail-less would
really appreciate it. Thanks
would be happy with it. Our mizzen staysail was embarassing to use
(pink, orange, lime green and blue) until I got a picture of what it
looks like from a distance. We love it and it turn a lot of heads as
we sail on. We enjoy calling out the order “Hoist the mizzen staysail.”On 10/12/2013 5:56 PM, Adam wrote:
135 %.
October 13, 2013 at 1:36 pm #80194
Ted Elaine
ParticipantWe have done the Isla Mujeres race 15 times. We have the original size on Bel Esprit II. By the way, I am looking for a new captain.
Elaine Patton
135 %.
