Forums General Discussion FW pumps
Viewing 7 reply threads
    • #68580
      Any opinions on these new style FW pumps such as FLo-Jet variable sensor
      units? Would 4.0 or 5.0 gpm be necessary for a galley sink and 2 heads?
      Thanks- I need to replace an aging Jabsco diaphragm style unit.
      Rodd Leeds
      Windseeker
    • #78610
      Our pressurized water system is driven by a Jabsco Sensor Max VSD
      31750 which draws from the tanks through an American Plumber W38-PRA
      (W.5CB) filter which can have one of several filters installed designed to
      remove sediment and chlorine or tiny little bacteria as needed.
      I think the Cold water side could benefit from an accumulator tank because
      the pressure is stabstantially higher on the HOT side which goes through
      the hot water heater. I don’t even know when we last turned that on, but I
      think it’s tank acts like an accumulator. That said, the pressure isn’t bad
      on the cold sider, it’s just better on the hot.
      Our old (original?) pump was so loud we were embarrased by it. This one is
      great!
      I should mention we elimintated the forward sink… saw no need for it!
      Plumbing overview: http://deepplaya.com/?p=160
      Pics of the V-berth Modifications:
      http://www.flickr.com/search/?w=26558453@N03&q=v-berth
      10 Months off the dock and all of these things have been worth it!
      -patrick
      @DeepPlaya |
      W7PEA
      Rodd Leeds
      Windseeker
      https://pearson424.org/mailman/**listinfo/maillist_pearson424.**org
    • #78611
      I was all over the VSD pumps, but have had two myself, had customers with
      one or more fail. Especially the leak detection ones. I went back to a
      simple pump and accumulator system.
      The fancy pumps are a great idea but are not ready for prime time.
      great!
      -patrick
      @DeepPlaya |
      W7PEA
      Rodd Leeds
      Windseeker
      https://pearson424.org/mailman/**listinfo/maillist_pearson424.**org<
      https://pearson424.org/mailman/listinfo/maillist_pearson424.org>
    • #78612
      I have heard that same comment from several people this winter on my travels south…. Simple is better.
      — On Mon, 6/11/12, Robert Fine wrote:
    • #78613
      That was my experience (what Bob wrote) several years ago. I went through
      three of the pumps before going back to one of the standard (constant
      speed) pumps. I hoped they had improved as they are definitely quieter and
      more efficient than the standard ones. Doesn’t sound like it.
      As to the volume, I believe my current pump is 4.3 gpm. That is more than
      adequate, but I rarely have more than one of four faucets on at the same
      time.
    • #78614
      Rodd
      I assume that this is the freshwater pressure water pump. The nice thing about the old diaphram pumps is that they are self-priming. I replaced mine with a Jabsco PAR wabble-plate pump several years back. It works well, but it doesn’t prime itself. If it runs dry, it can be difficult to prime. This can happen if the tank is low and the boat is on a tack that puts the tank on the low side of the boat. Mounting it low can help avoid this problem. I mounted mine on the side of the bulkhead below the galley sink. I wish I had mounted it lower. I installed an in-line water strainer and accumulator tank followed by a sediment filter.
      I have a backup foot-pump. I’m looking at moving the connections so that I could use it to prime the pressure water pump.
    • #78615
      joe shimkonis
      Rodd-I had a Jabsco 3 gpm but it became very loud when pumping.I went back to the Shurflo pumps because they claim to be quiet.I started with a 2 gpm and asked West Marine if I could return if if it didn’t provide adequate flow-it didn’t and I returned it for the 3 gpm.3 gpm provides plenty of flow-perhaps 4-5 gpm is overkill.
      I also installed new valves and hoses under the floor [mover from the sink cabinet wall mount] because I had a tendencyto overfill the tanks and flood the cabinet floor.I now how a white,uncluttered sink cabinet.
      Joe Shimkonis
    • #78616
      decided to go with a simple Shurflo 4.0 gpm pump and keep my accumulator
      tank as well. Tks for heads up on the VSD pumps- good idea, but if not
      reliable who needs it!
      Rodd Leeds
      Windseeker
