Forums › General Discussion › Fuel tank replacement
- This topic has 3 replies, 3 voices, and was last updated 16 years, 7 months ago by
July 30, 2008 at 9:48 pm #67109
ParticipantThinking it’s time to replace the aging fuel tank before it starts leaking. I need to raise the engine and move it far enough forward on the cabin sole to remove and reinstall the new tank. I figure to use a come-along supported by a 4X4 across the top of the companionway. Question is, how best to move the engine forward and away from its bed. Perhaps appliance rollers underneath both sides of the engine would allow me to roll it forward on cardboard or thin plywood to protect the cabin sole.
Any suggestions most appreciated!!
Thanks.
Rodd Leeds
Windseeker, #214Post generated from Pearson424 Forum using Mail2Forum
July 30, 2008 at 11:43 pm #70384
Participantuse a fixed-wheel roller (360 degree casters will roll the block around) and 1/8″ brown mdf cut to sole pattern. that’s how we avoided callbacks with big appliance installation and general refinishing over a nice floor. hint: also run it up the bulkheads to avoid unsightly dingers. clean floor first.
-Adam Silverstein-iPhone (“trust everyone but cut the cards”)
Thanks.
Rodd Leeds
July 31, 2008 at 12:14 am #70385
Participantthanks Adam– btw is your boat still in EH? give me a call when you get a chance-
Rodd
516-972-3042Quote:
July 31, 2008 at 4:58 am #70387
UG, metoo 🙂
I just got me a 55 Gallon barrel to hold diesel. Will the cockpit deck support that much weight in the back corner? I’m not allowed to keep the drum on the dock, and I don’t think I wanna move it after it’s full.
Thanks.
Rodd Leeds
