Forums General Discussion Emergency Rudder
  • This topic has 15 replies, 5 voices, and was last updated 11 years ago by Tor.
Viewing 15 reply threads
    • #68843
      Adam
      Has anyone fabricated or purchased an emergency rudder?
      Contemplating building one for Mexico race.
      Adam
    • #80602
      Adam,
      I’ve never heard of anyone fabricating an emergency
      rudder for a cruising sailboat, but I do have one on
      Silverheels. It’s the external rudder that’s part of my
      Auto-Helm windvane made by Scanmar Marine, the same
      outfit that makes the Monitor windvane (photos
      attached). If I lost my primary steering system or
      rudder, I could steer my boat with the Auto-Helm’s
      rudder via a second set of cables I had made up for it,
      which connect to a tiller-pilot (autopilot), or simply
      as it is designed to do via the windvane. Of course,
      one could also make a tiller for it.
      FYI, the old, traditional way to compensate for a
      busted rudder is by dragging warps and/or any handy
      objects off one quarter or the other, along with
      varying the sail trim.
    • #80504
      skipmac
      Have been researching the emergency rudder issue. If you haven’t already found this, the only way to go is a cassette rudder which is a structure that has a frame for the rudder to slide down into instead of trying to drop a rudder with pintles attached into gudgeons on the transom.
      The reason for the cassette design is that boaters that tried to install a rudder with the pinties attached found it impossible to line up the pins with the gudgeons on a boat rolling around at sea and flopping the rudder side to side.
      Google cassette rudder and you’re get lots of pictures and plans.
    • #80505
      Which reminds me… Scanmar Marine sells an emergency
      rudder, online at
      http://www.selfsteer.com/products/sos/index.php .
    • #80510
      skipmac
      I talked to Scanmar a couple of months ago while on the hunt for a large gudgeon and pintle set to build my own. They were very helpful, good guys but their emergency rudder setup was several boat units.
    • #80516
      Adam
      Thanks for the response. I’ve looked at cassette designs as well, but haven’t found plans of one for boat our size with someone who has used it in to sail the boat.
      I also saw price of scanmar rudder and was run off by the high price.
      Adam
    • #80522
      skipmac
      I found an article about building cassette rudders which gave some guidelines for calculating the size you need based on your existing rudder, position on the boat, etc.
      My plans are for in the water surface area of the cassette rudder of 50-65% of the existing rudder and 1″ diameter pintles. I am also thinking of adding s small balanced area towards the bottom of the emergency rudder to make it easier to steer with a tiller.
    • #80525
      Adam
      What is the approximate size of the 424 rudder?
      Adam
    • #80528
      About 2/3 of a barn door.
    • #80529
    • #80533
      skipmac
      Adam
      Will be at my boat tomorrow and measure it.
    • #80535
      Adam, give me a minute to get through a cup of coffee, and I’ll get the measurements for you………
      Leading edge vertical 41″
      Aft edge vertical 46 1/2″
      Across the bottom including gudgeon 28″
      Across the top horozontal 25″
    • #80538
      Adam
      Thank you ken.
      This will give me a start. I am having trouble on materials to use. Do you use wood covered wih fiberglass for rudder and cassette box. Or use aluminum reinforcement. Another way to consider would be galvanized pipe and plywood and consider it “single use” because of rust.
      Thanks Adam
    • #80551
      Adam, why not look at what is available in the boat for the use of an “EMERGENCY” rudder. Two teak cabin doors possibly screwed and bolted together with and added fiberglass leading edge. Two stainless steel ladder assemblies which could be dismantled to create pivot points off the transom, etc, etc. This is all of course for dire situations which may or may not happen.
      Honestly, to build a spare rudder and carry it aboard just doesn’t make a lot of sense to me. I think Tor has the best set up for an emergency rudder and all it costs is money and by golly it will steer your boat! It “is” the kick-ass answer to an emergency rudder and I wish I had his set up!!!!!!
      ken
    • #80553
      Adam
      Ken you are right!
      Tor’s setup is awesome and I too wish I had it!
      My purpose for the emergency rudder is to satisfy requirements for the regata al sol race from Pensacola to Isla Mujeres, Mexico.
      I was thinking something low tech and inexpensive way to satisfy the requirement.
      If I ever purchase a self steering system it will be like Tor’s for sure. I like the way he added a tiller auto pilot to the system, brilliant!
      Adam
    • #80592
      JodyandStephen
      Another rudder option is the ‘Seabrake’. These are legal for racing purposes for use as a back up rudder. Easy to stow, relatively light weight, and easy to pay out in rough weather, and they work. I know a vessel that completed their ocean race with one, sailing up river into harbour
