Forums General Discussion Deep (but dry) Bilge
Viewing 7 reply threads
    • #68294
      I’m not sure this is a novel idea or not, I stole it from another 424 owner
      (Doug Campbell – Mobjack Pearl).
      To get all but the the last few ounces out of the bilge – I installed a
      Whale Gulper pump on the decommissioned shower sump that straddles the bile.
      The pump is connected by way of a hose to a section of PVC pipe that
      terminates at the lowest point of the bilge.
      On the end of the PVC pipe I glued a cap that has 4-5 holes drilled thru
      it.
      After the lowest bilge pump is finished with it’s work and there is still a
      fair amount of water in the bilge, I activate the ‘dry bilge’ pump (switch
      at Nav station). In a minute or two, the bilge is essentially dry. I used it
      all last season and it works great to get the bilge dry and eliminate any
      smells the Admiral deems offensive.
      Attached is a photo that shows the hose and PVC pipe.
    • #77070
      Your idea sure beats trying to “shop vac” the remaining water. Do you then pump the water into a shower sump for directing it overboard?
      Lady Leanne II (#135)
      Ko Olina, O’ahu
    • #77071
      The “dry bilge” pump shares the same overboard as the shower pump… I don’t
      have a sump for the shower… it goes directly overboard…
      Eclipse
      Ko Olina, O’ahu
    • #77074
      Really? The shower sump is above the water line? I guess I could measure
      that. Doesn’t water come in when the boat heels? Especially to starboard?
      don’t
      Eclipse
      On Thu, Apr 21, 2011 at 1:37 PM, kalinowski <
      then
      Ko Olina, O’ahu
    • #77075
      Bob,
      The shower pan drain is well below the waterline. I’m sure Rick meant
      his shower water is pumped overboard directly from the shower stall
      drain rather than thru a sump. I set mine up that way, too, and use the
      original sump box beneath the floorboards for storage.
    • #77076
      That’s what I thought. Mine’s the same. I removed that box.
      On Apr 22, 2011 7:03 AM, “Silverheels” wrote:
      Bob,
    • #77078
      Correct… Sump has been inactivated… Shower is pumped directly
      overboard…
      Eclipse
      On Fri, Apr 22, 2011 at 7:02 AM, Silverheels wrote:
      Bob,
    • #77079
      Rick,
      I thought you might have a Y-valve on your shower pump that allowed
      you to use it as a backup bilge pump. I rigged that for awhile, when
      I used a macerator pump for direct overboard discharge of the shower
      water. Since that pump would not nomrally clog and didn’t require a
      strainer, I used it as a slow, but effective way to dry out the bilge.
      Unfortunately, while that pump (Whale) never clogged, it did break
      often. The failed parts were never in the repair kit offered by
      Whale. When the third of these pumps failed a few years back, I
      replaced it with a Jabsco that does require a strainer and gave up on
      the bilge drying solution.
      FWIW, the overboard discharge for my shower has a vented loop. That
      was installed either by Pearson or a PO. So no real worries about
      water backing up into the shower pan.
      On Fri, Apr 22, 2011 at 11:58 AM, Rick Dugger wrote:
      overboard…
      Eclipse
      Bob,
