Forums › General Discussion › Deck Drains
- This topic has 6 replies, 4 voices, and was last updated 16 years, 10 months ago by
unabated.
May 1, 2008 at 2:18 pm #66973
ParticipantTrying to find a suitable replacement for the midship
deck drains. The installed model is a PERKO 301-8
which is no longer made. I have found something
similar that would work. But none of them have that
nice little pin in the middle to keep the big pieces
out. Curious as what others have used.
alan____________________________________________________________________________________
May 1, 2008 at 4:45 pm #69742
ParticipantThe pin in the middle is likely a modification done by a previous owner.
See https://www.pearson424.org/plumbing/tt-cockpitdraingclog.html—
May 1, 2008 at 5:00 pm #69744
ParticipantI don’t think so, I have one off now and they are
factory done. I am talking about the deck drains, not
the cockpit drains.
Seehttps://www.pearson424.org/plumbing/tt-cockpitdraingclog.html
Quote:—
May 1, 2008 at 5:21 pm #69745
ParticipantOdd. Mine are all exactly the same. Then again, Pearson never made two the same.
May 1, 2008 at 10:36 pm #69746
ParticipantMy deck drains have the pin across the opening as well. Guess Pearson
changed a few times. BTW hull is 1983 #214.Rodd Leeds
May 2, 2008 at 4:13 am #69748
Hull #50 1978 or 79 (there’s a bit of a discrepancy) also has the pins that look factory installed.
On 5/1/08 3:38 PM, Rodd Leeds wrote :
Quote:My deck drains have the pin across the opening as well. Guess Pearson
May 2, 2008 at 10:13 am #69749
ParticipantAs anyone tried to replace these drains with the pins?
I have not been able to find an exact replacement.
— Aaron Lynch <> wrote:Hull #50 1978 or 79 (there¹s a bit of a discrepancy)
well. Guess Pearson
