Forums › General Discussion › Cutter Ketch inner stay position
- This topic has 10 replies, 5 voices, and was last updated 5 years, 1 month ago by
Stella Maris.
December 28, 2019 at 3:18 pm #225361
Stella Maris
ParticipantHi – I’m thinking about adding an inner staysail on my ketch. I read somewhere once that the boat was designed for this addition. Not quite sure what the length of the stay should be, or where precisely it should be attached to the foredeck.
Anybody out there who can advise? And how is the stay reinforced below the deck on the inside of the attaching point?
Thanks for any advice or photos –
Chris
December 28, 2019 at 3:52 pm #225362
Chris
I’m interested in what you find out. I have a 422 center cockpit ketch.
JohnJ. WARNER EVANS, PhD
s/v A Piacere
Pearson 422 #5
[formerly, Windsong] -
December 29, 2019 at 8:33 am #225363
ParticipantHi Chris and John,
We have a detachable inner stay on our 1983 424 ketch Juniper.
We have not used it yet, but here is a photo of the attachment point right behind where our furler/forestay attaches.
We know this as a Solent stay. Whether that’s the correct term, I’m not sure. The stay is wire and has a large lever and clasp that attaches to that point For easy hookup. Tension is adjusted by a halyard at the base of the main.
I hope this is helpful. The boat is currently wrapped up on the hard otherwise I’d make a little video and show you how it attaches.
Ryan and Kathleen
Juniper-
This reply was modified 5 years, 2 months ago by
Ryan Doyle.
December 29, 2019 at 8:38 am #225366
December 29, 2019 at 8:45 am #225368
Stella Maris
ParticipantThanks, Ryan, but I’m looking for an actual inner stay, not a solent. They look to be placed further back, in the deck over the V-berth.
I am curious, though – what’s the purpose of this particular solent, so close to the forestay? Will you run a drifter or something on it in light wind?
And where do you store the stay to keep it out of the way when it’s not hooked onto the foredeck?
Thanks – Chris
December 30, 2019 at 8:49 am #225377
Stella Maris
ParticipantJohn – there’s a great discussion about all of this from about four years ago here:
It looks as though a true stay sail would attach to a fitting directly aft of the anchor locker bulkhead, reinforced under the deck with a chainplate fitting that transfers the stress to the bulkhead itself. Pretty simple and ingenious.
Lord, there’s a lot of great stuff in the forum archives of this site.
Chris
January 5, 2020 at 9:02 pm #225385
Bryan Bywalec
KeymasterNot Pearson specific but generally an inner stay runs parallel to the forestay and meets the mast at the same place as the head of a reefed main sail. This way the leech of the mainsail helps support the load from the inner stay; otherwise you’d have to consider check stays to prevent the staysail from bending the mast at the attachment point. 2/3 up the mast is a general location and parallel to the forestay from there…
Bryan Bywalec
S/V Pelican, Hull 209
Siren Engineering, LLC -
January 5, 2020 at 10:15 pm #225389
Pjfuce
Participanti have a cutter rigged ketch, i have yet to fly the storm jib but i did rig it up see pics attached. i have running back stays on main and mizzen mast, i will take additional pics of how storm stay connects to deck which is behind anchor winch.
paul
January 6, 2020 at 10:36 am #225391
Dennis Home
ParticipantI have flown my yankee in 40 knots of wind with a double reefed main it sails along very comfortably.
January 6, 2020 at 3:17 pm #225392
Dennis Home
January 6, 2020 at 6:49 pm #225397
Stella Maris
ParticipantThese are great pictures, Dennis, thanks so much. A couple of questions for you-
1) how did you attach the tangs to the mast for the back stays? Did you reinforce the mast in any way at that position?
2) Do the running backstays attach directly to the toe rail?
3) I’m having a hard time seeing in the pictures what you’re showing me in the anchor locker and the windlass.
4) Just out of curiosity, what does that 1/2″ metal plate with the holes in it in the anchor locker do for you?
Thanks again – this is a huge help.
Chris
