Forums Announcements creeping throttle
Viewing 3 reply threads
    • #225987
      stan dekiel
      Good day,
      I have an early sloop with a W-58. The throttle lever creeps forward as I motor. I thought it must be a lack of friction at the brinicle but after purchasing a new linkage lever I find that is not the case. Any suggestions?
      Stan
    • #225988
      It sounds like the throttle cable was recently replaced. This is common with a new cable. Get a cable clamp and put it around the cable near the engine, not a hose clamp. Tighten it to firm but not too tight. Adjust until it feels right.
    • #225989
      Eric Lorentzon
      Does it do this at idle as well or only underway?
    • #225990
      This will fix your problem at any engine speed. If you tighten it too much, you can’t even move the cable. Start loose and adjust until it feels right.
