Forums › General Discussion › Cooliing System Flush
- This topic has 25 replies, 10 voices, and was last updated 12 years, 1 month ago by
Chuck Ruble.
October 11, 2012 at 1:48 pm #68629
ParticipantI’d like to flush out the cooling system on my W 58. Has anyone done this? What product did you use? Where are the drain plugs on the W 58 located?
Ko Olina, O’ahu -
October 11, 2012 at 1:58 pm #78864
ModeratorHi Dan,
You can flush with any product that doesn’t harm aluminum. The drain plug
is on the starboard side of the engine just forward of the dip stick, I
think. Draining the engine isn’t all that complicated, but be sure you
drain the water heater (and fill it) separately or you’ll be with no hot
water and with an overheating engine. Also, make sure that the engine is
totally full, including the thermostat housing. Sadly, the way it’s
mounted, the thermostat is higher than the vent valve in the expansion
tank, meaning you can get an air bubble there and the associated
overheating (within minutes of starting the engine). How do I know?
Experience….Bob
located?Dan Kalinowski
October 11, 2012 at 3:26 pm #78865
ParticipantBob: thanks for the tip. By the way, how do you get the air bubble out of the thermostat housing?
Ko Olina, O’ahu -
October 11, 2012 at 5:42 pm #78866
ModeratorThat’s an interesting question. I ended up having to remove the housing (2
bolts easy to get to) and filling the antifreeze into the water pump.
Basically, your engine should take 2 or a little more gallons of
antifreeze, and if you can’t get it in using the fill and run method, that
was the only way I could figure out how to do it. You may not have the
problem at all – I did. But if you do, you know how to deal with it.Bob
of the thermostat housing?Dan Kalinowski
October 11, 2012 at 8:53 pm #78867
ParticipantOur W-58 has a petcock on the side of the upper t-stat housing to vent air. Absent that, you might try loosening the clamp on the “L” shaped hose between t-stst housing and exhaust manifold. We also have an overflow tank in the port cockpit locker that is teed off the hoses to the hot water heater.
October 11, 2012 at 8:55 pm #78868
ModeratorEven better! I wish I had that.
On Oct 11, 2012 4:54 PM, “quent” wrote:Our W-58 has a petcock on the side of the upper t-stat housing to vent
heater.
October 11, 2012 at 11:01 pm #78869
SpectatorYou may have this and I only say that because I didn’t know it till the
guys on the list taught me.The petcocks look like thin pieces of metal with a pressed end. They don’t
look like much at all to be honest and I had no idea what they were till
something similar came up on the list.
They vent air (or whatever the fluid is there).-p
@DeepPlaya |
air. Absent that, you might try loosening the clamp on the “L” shapedhose
tank
heater.
October 11, 2012 at 11:17 pm #78870
ParticipantBased upon the comments here, it would seem to make sense to have a bleed valve installed on the top of the thermostat housing. I’m thinking of one shaped like a wing nut that can be hand tightened. Would the engine block coolant drain plug be part #11 on page 200 of the W 58 parts manual?
Ko olina, O’ahu -
October 11, 2012 at 11:40 pm #78871
ParticipantJust a quick note: The petcock with the opening between the two handle wings typically opens by screwing in, not out.
Q -
October 12, 2012 at 12:44 am #78872
ModeratorExcept on the w58. Right to tight, left to loose.
On Oct 11, 2012 7:40 PM, “quent” wrote:Just a quick note: The petcock with the opening between the two handle
Q_______________________________________________
October 12, 2012 at 11:47 am #78873
Participantone note on the antifreeze to be used. Westerbeke recommends using the
Prestone Extended life coolant now. If you are replacing another type of
coolant, like the green coolant that we used to use, you need to be sure and
get all the old coolant out of the engine before adding the new extended
life. They were insistent that it is a bad idea to mix the two types of
coolant!So, best to drain coolant by pulling the hoses off the bottom of the main
heat exchanger, and also remove the engine block plug, which is on the right
side of the W 58, but the port side of the boat. then place a hose and
flush with fresh water. this will ensure you get all the old antifreeze
out. then fill witht the new extended life. then deal with the air lock
problem we all have!!Rodd Leeds
Windseeker
October 12, 2012 at 11:55 am #78874
ModeratorIn an effort to be green, I installed the West Marine stuff, I forget the
name last year (serves me right for fixing things not broken, as there’s
plenty of broken stuff to deal with). Oh, wait, I did it because I had to
replace the water heater. Anyway, flush and fill the water heater
separately. Really important. If you have a compressor available, use it
to blow out the water heater after flushing.That’s all I have to say about that. It sounds far more complicated than
it really is.Bob
On Fri, Oct 12, 2012 at 7:48 AM, Rodd Leeds wrote:
Quote:one note on the antifreeze to be used. Westerbeke recommends using the
and get all the old coolant out of the engine before adding the new
extended life. They were insistent that it is a bad idea to mix the two
types of coolant!So, best to drain coolant by pulling the hoses off the bottom of the main
right side of the W 58, but the port side of the boat. then place a hose
and flush with fresh water. this will ensure you get all the old
antifreeze out. then fill witht the new extended life. then deal with the
air lock problem we all have!!Rodd Leeds
Windseeker
October 13, 2012 at 12:37 pm #78875
ParticipantThanks for the tips! It’s great to have this resource for a 32 year old boat. I’ll have to check on where to fill the water heater.
Ko Olina, O’ahu -
October 13, 2012 at 12:44 pm #78876
ModeratorEasy, just pull both hoses and fill one until water comes out the other
then reconnect. Should take a bit more than a quart, maybe a quart and a
half.I’m not being terse. This is from my mobile.
On Oct 13, 2012 8:38 AM, “kalinowski” wrote:Thanks for the tips! It’s great to have this resource for a 32 year old
boat. I’ll have to check on where to fill the water heater.Dan Kalinowski
October 16, 2012 at 3:18 pm #78877
cstewart
ParticipantIs there any reason to believe I wouldn’t have this same air-lock problem inherent in the W60? I need to refresh my antifreeze but don’t want to invent any problems that I don’t already have.
Charlie
October 16, 2012 at 4:02 pm #78878
ParticipantCharlie,
Yes, I usually had an airlock problem with my W60 when flushing the
coolant. Almost always it was in the hoses going to the water heater. I
disconnected the hoses and poured antifreeze into one hose until it was
flowing out of the other hose, then reconnected the hoses to the engine.
That always fixed the problem.Regards,
invent any problems that I don’t already have.Charlie
sight of the shore."
October 16, 2012 at 6:44 pm #78880
cstewart
ParticipantThanks. I second Dan’s comment about how nice it is to have this forum for our 30 year old boats. This is better than a manufacturer’s advice on a new boat. Theirs is theory, this is experience.
October 17, 2012 at 11:56 am #78881
I have a Yanmar, but I’m wondering… I changed the antifreeze last
spring just before I stored the boat for the summer. Then I only ran it
for a few minutes to move to the haul-out slip. Seemed fine doing that.
How does one know one has an air lock in the engine’s cooling system.
What is the symptom?I’m not being terse. I’m being curious.
October 17, 2012 at 12:31 pm #78883
ModeratorAn airlock will result in overheating within 5 minutes. As far as the
engine knows, there’s no water in it (not true, but thats how it appears to
instruments and sensors). If it didn’t happen then, then when you leave
next time, make sure your sails are uncovered and your anchor’s ready!Or, just run the engine for 10-15 minutes and allow it to come up to temp.
On Wed, Oct 17, 2012 at 7:56 AM, Silverheels wrote:
Quote:I have a Yanmar, but I’m wondering… I changed the antifreeze last
October 17, 2012 at 1:11 pm #78884
Glad I asked. Thanks.
October 17, 2012 at 1:37 pm #78885
ModeratorFunny story. I changed my coolant last fall when I winterized. Ran engine
at dock for a few minutes to be sure it would run.Left dock and made it about 200 feet before alarm went off. Couldn’t
anchor in mid channel so threw up sails, deciding that I could sail to safe
anchorage in harbor, then get towed in.Got to safe anchorage and decided I could sail around the sound for the
day, then get towed in.Wind was great for going to Manhassett to see friend there. Sailed for the
day and up to anchor.Had a great time with friends, took 10 minutes the next morning to deal
with engine, and sailed home.Moral of the story: it’s a sailboat. The engine is called auxiliary for a
reason.Bob
On Oct 17, 2012 9:11 AM, “Silverheels” wrote:Quote:Glad I asked. Thanks.Tor
October 18, 2012 at 12:58 am #78886
ParticipantOr you hot watet heatet never heats up.
Sent from my Samsung smartphone on AT&TRobert Fine wrote:An airlock will result in overheating within 5 minutes. As far as the
December 12, 2012 at 3:38 am #79041
ParticipantQuent: thanks for the idea of a vent for the upper thermostat housing to bleed that area. I bought a spare W 58 from another owner that repowered and use it for parts. The upper thermo housing on the spare engine had a threaded port that I believe was used for a temp sensor. The port threads fit a petcock that I bought at an auto store, and I removed and replaced the original housing with this now vented unit. Westerbeke must have changed the thing on later engines.
After going through the frustrating process of methodically rebuilding the raw and fresh water systems, my overheating problems are finally solved. This air bubble problem, of course, is not mentioned in any engine literature and had me tearing my hair out. I offer the following guidelines:
1. Never, ever mix antifreezes. The resultant goo plugs up the cooling passages. Yes, I unknowingly did this
2. Never, ever use a flush product unless it is friendly to aluminum. After gumming up my system, the flush I used ate holes through the inlet/outlet pipes on the aluminum exhaust manifold. Lucky I had a spare engine.
Duh!Hopefully this will save another W 58 owner some grief.
Ko Olina, O’ahu -
December 12, 2012 at 3:55 pm #79042
ParticipantFlush with clean water and some powdered dish washing solution. Run, flush, run, flush until you get clean water coming out.
The engine won’t heat up to operating temp in neutral. Run it under load at the dock to get it to heat up.Use red, heavy duty, silicate free anti freeze.
December 12, 2012 at 4:03 pm #79043
ParticipantOh yeah, those drain plugs. We usually remove them and plug. There’s no reason to open them, you can drain the system from a hose and they often just result in nuisance leaks.
February 3, 2013 at 12:57 pm #79203
ParticipantOne of these turned up at the shop. I’m thinking of plumbing it to the horizontal temp sensor on the thermostat housing with a short length of flexible hose. Mounted on a bulkhead it would be the highest spot in the system.
http://www.watts.com/pages/_products_details.asp?pid=663
Something to check out on your cooling system. The hole in fill port on the cooling system that leads to the overflow tank hose gets clogged quite easily. You can stick a paper clip in there to clear it.
