Forums › General Discussion › Bluewater Structural Modifications
- This topic has 6 replies, 7 voices, and was last updated 8 years, 10 months ago by
sumocean.
April 11, 2016 at 10:07 am #220491
Site Administrator
KeymasterAll,
Since I am deep in the thick of some pretty extensive fiberglass work, I wondered if there were any suggestions as to where I can strengthen the hull and deck for a little heavier offshore sailing:
– thus far I have strengthening the bilge
– stiffening the bow to prevent oil canning in heavy seas
– I’ve the L-shaped galley layout, and the PO put a couple of stainless bars in to hold the deck up amidships where the settees begin. I’m planning on replacing this with a curved support acting like a beam on the cabin top.Anything else?
info@pearson424.org -
April 11, 2016 at 11:29 am #220493
Rob Osterman
ParticipantEwan,
I’d be interested in this as well.
Rob
April 11, 2016 at 4:47 pm #220499
ParticipantVery much interested in this topic.One item, some have said to reinforced the stern as well.I understand that it’s important to not put hard spots into the hull when reinforcing. This means using material with similar flex characteristics as the hull. Read: use vinyl ester not epoxy. Epoxy will have a different flex and in a rough sea hard spots would create local stresses and might pull the reinforcement apart. If P424 hulls were epoxy, that would be another matter.Note: this is what I’ve read, I don’t have first hand experience in this area. Would love to hear from those with days of heavy seas experience.RogerAttachments:
April 11, 2016 at 5:32 pm #220502
ParticipantThe wide flat section of the aft portion of the hull certainly will flex. My surveyor pointed that out to me by pushing the hull with a stick and watching it flex. The forward section is probably more critical because it will take more punishment in rough seas.I have no recommendation for fixing this issue as I made two Atlantic crossing on the original hull. I'd rather be lucky than good. -
April 11, 2016 at 6:12 pm #220503
ParticipantI’ve long wondered how the throw rugs in my cabin can migrate across the floor. This flexing could be the reason. -
April 11, 2016 at 8:42 pm #220507
ParticipantI canât think of any flat sections aft other than the transom, which is actually pretty thin. Iâve observed no hull flexing other than the bow which I rebuilt years ago.
If you have a sloop or cutter, the transom chain-plate is poorly attached.
April 14, 2016 at 6:35 pm #220516
ParticipantEwan
Please post a few pictures when you make some progress. I am interested in the beams at the end of the settees and how you plan to integrate these with the existing woodwork. Thanks also for all the work you have done on the website.
