Forums General Discussion Bilge Pumps…
    • #225011
      All,
      I want to replace my very old bilge pump …
      I am not happy with the original way it was mounted on a board and PVC pipe..
      I also want to add a “high water” second pump attached to the bilge alarm..
      My thought was to build a double mount with the main pump at the lower level at the bottom and a second “high water” pump half way up the bilge.
      I was hoping some one had an idea of how to build and install the brackets/mounting..
      Or had a better way to accomplish the same thing..
      It would need to be easily removed for cleaning and maintenance..
      I’m stumped so your thoughts would be greatly appreciated..
      John Dunphy
      Mela
      S/V Mela
