Forums General Discussion Autopilots, wheel mount or below decks?
Viewing 24 reply threads
    • #68239
      jamesminge
      I am refurbishing a 1980 424 which has no auto pilot. Can I get away with the $1500 Raymarine wheel mounted smartpilot. It is recommended for max 16000 displacement boats, but since the 424 seems to have little helm, I thought I might get away with it. Or should I get a below decks model which will cost at least $3500 more? I would like to think I will do a bit of offshore (three days max) at some point, but don’t plan to cross any oceans. Which manufacturer makes the unit most compatible with the 424 which requires no quadrant work or other major modification? All replies appreciated, thanks, Jim
    • #76891
      Jim.
      IMO, the wheel pilot is probably adequate for ICW motor trips, but not
      off-shore where the seas will over-power it. It is also likely inadequate
      for sailing under autopilot in anything more than 10-12 kts of wind. The
      only 424 that I know of that has made ocean passages and long cruises with a
      wheel autopilot is Whoosh. However they make great use of their Sail-O-Mat
      windvane and rarely motor on a passage except in dead calms. I had a
      Raymarine wheel pilot that came with Sarah, which is basis of my negative
      opinions.
      I think most of the autopilot manufacturers use a tiller mounted on the
      rudder shaft rather than attach to the quadrant. Raymarine works that way.
      The only mod for my Raymarine installation was the glassing in of a mount
      for the drive unit.
    • #76893
      Indulgence
      Hello Jim,
      Here’s a summary of my recent experience:
      For 5 years we did primary coastal cruising and a few over-nights. I had an
      older Cetec-Benmar below decks autopilot. This pilot worked great and was
      fine for what we used it for. This past fall, I sailed the Caribbean 1500
      to Tortola and thought that my autopilot was up to the job…it wasn’t and
      it failed the first night off Cape Hatteres. We were forced to hand steer
      the remainder of the 11 day trip.
      It turns out that the almost half the of the boats sailing the 1500 had an
      autopilot failure. Virtually all those failures were with older pilots like
      mine or with Raymarine below decks and the wheel pilots.
      In Tortola I upgraded my autopilot to a B&G Ram with a Simrad head. This
      required some customized mounting and an quadrant arm to be mounted. I am
      very satisfied with this new system and have no issues on our short
      off-shore passages between islands. I would estimate a robust off-shore
      autopilot would be between 6 and 9K with installation. In my opinion, 3.5k
      wouldn’t by you a reliable pilot….you’d be better off buying two wheel
      pilots.
      If you are not ever going to take the boat off-shore, then a wheel pilot
      would be fine. However, if your plans include a multi-day off-shore
      passage, I would strongly suggest that you bite the bullet and upgrade to a
      robust below decks pilot.
      s/v Indulgence # 179
    • #76895
      Plus one on spending the $$ upfront for a strong – reliable – fast pilot.
      I have done 4 passages of 5+ days offshore. It’s nice to know that the pilot is up to the task, especially off the wind where the boat really slews around. (where the lock to lock time needs to be fast enough to keep up)
      I use a RayMarine control head (X30) with an Octopus Hydraulic Ram. The nice thing about the Hydraulic ram esp. with Octopus is that it’s repairable with common tools at sea.
      The Raymarine Linear servo uses a small plastic pinion gear to drive it and you have to send it back to have it repaired.
      Mount the ram on an arm connected to the rudder post.
      My 2 cents
      UNABATED
      #140
      — On Wed, 3/16/11, John Sommer wrote:
    • #76896
      I wouldn’t suggest a wheel autopilot. My 424 weighs in at 24000 lbs without
      beer onboard. If your budget will handle only $1500, consider a used
      autopilot.
    • #76633
      skipmac
      If you are only coastal cruising or island hopping you can get away with a wheel pilot. For long distance sailing I would prefer a below decks unit.
      Below decks units will all require similar attachment to the quadrant and a solid attachment point to the hull.
    • #76900
      Connection to quadrant is really not the preferred method due to it’s weak construction. Need to mount it to the rudder post via a “tiller” arm. The tiller are can easily be purchased through Edson. This will also allow you to mount the unit lower in the boat. My ram is mounted to that large piece of lumber that surrounds the post.
      — On Wed, 3/16/11, skipmac wrote:
    • #76634
      Jim-
      Regarding a below deck unit, Edson the steering unit manufacturer is pretty much opposed to attaching to the steering quadrant. Tiller arms are available from other sources.
      There are several discussions regarding autopilots on this forum. Suggest you try a search.
      Quent Kinderman
      Clairebuoyant, #132
    • #76635
      skipmac
      @quent wrote:
      Jim-
      Really? I missed that one. The drive for the Autohelm that came on my Pearson was attached directly to the quadrant. Guess another foul up from the PO.
      Any particular reason why Edson is opposed to attachment to the quadrant?
      Skip
    • #76636
      Hi Skip-
      My understanding from talking to Edson guys at boatshow is that an autopilot drive puts a lot of force on the quadrant that it wasn’t designed for.. Their catalogue is pretty explicit about not doing it.
      I seem to remember literature from some some autopilot company, maybe Autohelm or Navico that showed their product bolted to a quadrant so opinions differ. Maybe your PO was acting on the best availble information.
      A good bronze tiller arm can be had for a couple hundred dollars and provides nice redundancy for the whole system. We mounted ours on the rudder shaft below the quadrant.
    • #76637
      skipmac
      I may have to think about this one. One one hand, it takes the same total force to move the rudder whether one does by the Edson cables or an AP drive arm. But, the cables are a pull/pull system and are connected to the quadrant at designated points so may better disperse the overall force than the AP attached at one point.
      On a semi related issue, have you tested the emergency tiller? I hooked mine up while on the hard and can barely move the rudder due to resistance in the cables and steering system. I think that would have to be disconnected if circumstances required use of the tiller for any time at all.
    • #76901
      Not much to think about really – if you hook the autopilot to the quadrant and the cables break, or  loosen up  and come off the quadrant or one of the pulleys, which happens all too frequently – you have no manual steering AND no autopilot. If you hook the autopilot to the tiller arm on the rudder post you can at least steer the boat thru the pilot. The chances of the tiller arm breaking, I would have to say, are slim to none given it’s size.
      On a related note, at least on my boat – the keyway and key for the quadrant was long enough to catch the keyway in the quadrant. SO, I did not have to do a bolt through – which would have been a b***h to do given the size and material of the rudder post.
      Just a thought
      — On Thu, 3/17/11, skipmac wrote:
    • #76903
      While we’re talking about autopilots and possible failure points – it got me thinking about a blog I wrote while on my trip. It has to do with spares and advanced failure mode planning.
      Hope you don’t mind…. it’s not that far off subject.
      “For months now I have been professing the need for spares. Not only for
      your primary devices but also for your backup devices as well. Not only
      do you need a Plan A for your primary device but you need a Plan A for
      your backup devices also. When your primary device fails, breaks, gets
      lost, falls overboard or you just plain forget how to use it, You need a
      plan to fix, repair, find, retrieve or read instructions for that
      device. The same holds true for your backup device as well because that now
      becomes your primary device. So now you need to be able to recover from
      the loss of use of that device as well. Get it?? So after 9 months and
      close to 5000 miles, I have found out where my failings are (and trust
      me there are many). The one that sticks out this morning is the failure
      of the can opener. I can’t even begin to tell you how frustrating it is
      to be offshore in 20+ knots of wind, seas running to 10 + feet and you
      can hardly stand in one spot, to not be able to open a #*&^%G can
      of beans. So let that be a lesson to all who go out to sea……. Must
      be something in the tool box I can use to open that can………. a
    • #76638
      My guess would be that an accidental disconnect between the steering system and the rudder would be the only reason to use the emergency tiller. That would eliminate the friction.
      In theory, the autopilot could replace the steering system but the only steering failure we have ever experienced was in the electronics rendering the autopilot useless..
      Maybe you could attach lines to the emergency tiller to control it.
      Best just to inspect and maintain primary steering system.
    • #76904
      Because of the difficulty of the emergency rudder operation, the next time I
      take Pelican out of the water, I’ll be putting two pad eyes (one backing the
      other) on the aft upper corner of the rudder. When I’m about to go
      offshore, I’ll attach lines to the pad eyes and loop them over the stern
      rail until (if) they’re needed. Then I can run them to the aft winches if
      necessary.
      It will keep the cockpit clear of that huge pipe and whatever rigging is
      required. I know someone had an eye welded to the emergency rudder so they
      could use a block and tackle (or more properly, a handy billy) to assist in
      the steering.
      Edson doesn’t want you to use the quadrant because it’s not designed for
      that kind of loading. When you see the tiller arm, you’ll see what I’m
      talking about. To connect to the quadrant means you’ll be piercing one of
      the radial castings which will weaken it. Take Edson seriously. I suspect
      they’ve seen that kind of failure.
    • #76639
      skipmac
      Completely agree. Keeping the primary steering system in order always the best option but I do like to make sure the emergency system works. By that I mean it actually works and doesn’t just look good in port.
      Like you, the only failures I have experienced were in the AP itself but have had friends that had to use the tiller before. In one case in a new Gulfstar 50 a part failed due to a bad casting that was undetectable until it broke. Hard to guard against that sort of failure.
    • #76640
      Speaking of undetectable until it broke, have you inspected the chainplates?
    • #76641
      skipmac
      Yes. Removed all the chainplates for the shrouds and even though they looked fine, went ahead a fabricated new ones. Next step is to remove the bolts on the fore and aft chainplates for inspection. Those are a bit more of a fabrication so hoping I can keep them.
    • #76905
      I never liked the emergency tiller setup on the 424. One would think that
      if the steering failed, it would happen in rough conditions. Having to open
      up a 4″ hole in the cockpit sole to attach the steering tiller doesn’t sound
      like a good idea. It seems that the rudder should have some kind of rubber
      gasket that seals the hole when in use.
      I don’t know if you folks have tried to open the tiller plate but it’s a
      bear. It’s a good itea to grease the threads every now and then.
    • #76906
      I have rigged the emergency tiller with tackle, but I sure hope I never have
      to use this arrangement, especially single-handed. It’s there and it might
      get me home, but …
      I’m not sure there is any good solution to the emergency tiller for this
      boat. That’s the bad news. The good news the reason the emergency tiller
      is difficult is that the rudder is pretty robust. Beyond a major hole in
      the hull, the worst situation I can think of when off-shore is the loss of
      the rudder. That is an unlikely event with the 424 as long as the skeg
      holds together.
      With a balanced spade rudder an emergency tiller is very practical,
      unfortunately it may have nothing to turn if something strikes the rudder.
      Rich is right about checking the deck plate for the emergency rudder. Mine
      was seized and I had to replace it.
      open
      sound
    • #76907
      My access plate is a pry-out arrangement instead of a screw-in one.
      Must have been changed out by PO.
      As for sealing the hole when using the emergency tiller, how about a
      towel stuffed in the gap. Nothing too fancy.
      get me home, but …
      holds together.
      open
      sound
    • #76642
      We have replaced a good bit of stainless steel. Chainplates, all but bow (Clairebuoyant is a sloop rig) companionway ladder risers, mast tangs just below spreaders. We’re watching a suspicious spot on the anchor roller frame, and a couple of the bolts holding it to the hull.
    • #76913
      Quent/ALL:
      I hope to replace my chainplates this summer. Did you replace yours with
      the mast stepped? If so, can you give me any advice or the procedure by
      which you replaced the plates, and how you supported the rig in their absence?
      thanks, BILL
    • #76914
      Support the rig with the head and back stays and use the halyards to the
      side. Replace opposite chain plates two at a time. As long as there’s no
      real strain on the rig, you’ll be fine.
      Call Hayn (Hayn.com) – they have a high pressure water cutter and they can
      cut new ones pretty quickly. Talk to Fred and tell him I sent you. They
      are really nice people. If you need a company to order them, I can do it
      for you – I’m on their books as tax exempt.
      On Sat, Mar 19, 2011 at 1:33 PM, wrote:
      Quent/ALL:
      absence?
      thanks, BILL
    • #76915
      Thanks, Bob. I suspected that procedure but needed the reassurance. And
      thanks for the offer of help w/HAYN; I just may do that and appreciate it.
      BILL
      BILL TICE~in residence ~*I*I*TREEHOUSE *I*I*I*~ Smith Mt. Lake, VA
      In a message dated 3/19/2011 1:39:21 P.M. Eastern Daylight Time,
      writes:
      Quent/ALL:
      with
      absence?
      thanks, BILL
