Forums › Announcements › attaching a tiller mount to rudder shaft for autopilot
- This topic has 4 replies, 3 voices, and was last updated 5 years, 6 months ago by
Rock Richardson.
June 29, 2019 at 5:53 am #225105
Rock Richardson
June 29, 2019 at 6:39 am #225107
Seawater
ParticipantYes. I did and it working well for over a decade. You should make it easy to remove so you can still use your emergency tiller
June 29, 2019 at 7:07 am #225108
Rock Richardson
ParticipantWhat did you go with as far as a tiller , hydraulic or mechanical, do you use it sailing or only motoring I’m an looking at hydraulic, either 7 or 12 inches long
how did you measure it.? where did you put the tiller base? Sorry for all the questions but I am new to thisthanks
Rock
SV Topaz -
June 30, 2019 at 3:42 pm #225113
Bryan Bywalec
KeymasterWe are currently fitting a B&G T2 hydraulic ram coupled to the NAC-3 computer. We’ve seen boats that used a tiller on the square part above the quadrant but elected to go with the Edson Tiller Arm that fits below the quadrant. It isn’t cheap but we didn’t want to make fitting an emergency tiller that much harder. We are using the 10″ one.
I’ve attached a picture of what the tiller looks like above the quadrant on another Pearson 424 in our area with the same T2 ram. Sorry they aren’t better quality, I took the pictures after three bushwhackers.
The last photo is of our boat with the proposed location of the ram. The tiller arm is on its way and should be installed on the 13th. We had to build a foundation for it to sit on but haven’t glassed it in yet as we want to confirm the setup with the actual tiller. What is shown is a mock up.
Right now I’m trying to locate a good spot to mount the solid state compass and computer!
Jefa makes a direct drive electric unit that we were considering but ended up going with the T2 ram based on our research. We will use it both sailing and motoring.
Bryan Bywalec
S/V Pelican, Hull 209
Siren Engineering, LLC -
September 3, 2019 at 3:02 pm #225225
Rock Richardson
ParticipantI decided not to attach the rudder arm to the square emergency tiller head but went lower I attached an octopus hydraulic ram and a rudder feed back on the opposite side, I also went with the NAC 3 computer. have done the dock test but not the open water test, soon ill let you know how it works
rock
